OMG Look at this!
Discussion in 'Hangout Lounge' started by jim123, Mar 2, 2011.
  1. jim123
    jim123 Member
    Chicago,Il
  2. Zookie400
    Zookie400 Active Member
    Connecticut
    see what happens when you dont run pods?
  3. Militant_Buddhist
    Militant_Buddhist Member
    Redmond, WA
    GOSH, I wonder how that happened?
  4. Alive
    Alive Active Member
    Queensland, Australia
    BOOM.... What a waste
  5. i_am_the_koi
    i_am_the_koi Member
    Napa, CA
    That's like amazing in that it was able to keep running on the other 3.... atleast idle with 3....
  6. andrewlong
    andrewlong Member
    Cumming, GA
    Beat me to it, lol
  7. Ravenz07
    Ravenz07 Member
    Morons. I would have given them 50 cents for it.
  8. mlew
    Its a parts bike now, what a waste.
  9. waldo
    waldo Member
    San Jose, Ca. 95125
    Holy CRAP!!!! Do it again. Zookie if thay had pods they would still be trying to blow it up
  10. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    That is exactly what happened to Maxim-X. I was riding to work and the bike shuddered, I revved it a couple of times but there was no power. So I pulled off to the side of the road , got off and started to check out the bike. Low and behold the 2nd cylinder from the right (as you sit on the bike) had snapped the rod off just below the piston.
    The rod took out the bottom part of the barrel, smashed through the front of the case, came back up and took out the back of the case and just stuck there.
    I could see through the motor from front to back!
    I could see the crank turning and the pistons going up and down and it was still idling as though there was nothing wrong.
    Frickin Twilight Zone or what?
  11. Darth_Menace
    Darth_Menace Member
    Alberta
    what in the world are pods?
  12. Zookie400
    Connecticut
    "pods" are clamp on air filters. where the name pods came from i dont know, only hear it on the pavement forums, dirt guys dont use the word so i had to look it up myself when i got my xj.
  13. fazerkid78
    fazerkid78 New Member
    Panama City Beach, FL
    No worries! That's just the new crankcase ventilation system!
  14. JeffK
    JeffK Well-Known Member
    Just North of Annapolis MD
    I don't see an issue. It's now a TRIPLE!!!!
    LOL
    jeff
  15. schooter
    put some chambers on and run it
  16. Saber
    Saber Member
    Reading, PA
    Isn't that a normal way to check out a bike your potentially about to buy?
  17. cutlass79500
    lawrenceville georgia
    actually that happens when you cut the upper back half of the frame every time .Takes the rigidity out of the frame and breaks the motor every time . If your bobber hasn't broke your motor yet you better get down and look for cracks wont be long if it hasn't happened . lol
  18. schooter
    The harley guys didnt even know what to do with rpm's like that
  19. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Some people just shouldn't own bikes.
