What is this cable?
Discussion in 'XJ Technical Chat' started by Darth_Menace, Mar 29, 2011.
  1. Darth_Menace
    Darth_Menace Member
    Alberta
    hey, i'm trying to get my bike ready for the season, and i see this coming out from the front of my has tank. can anybody tell me what this is, and where i plug it in? :lol:
  2. Darth_Menace
    Darth_Menace Member
    Alberta
    subsribing...and my second picture
  3. stunnuts
    stunnuts Member
    Pierre, SD
    It's hard to tell with the picture but you should check on your handlebars and make sure that that wire doesn't plug in somewhere up there. I'm not sure but the clutch may have a switch that that plugs into but without seeing what the end looks like i can't say for sure.
  4. macros10
    macros10 Member
    Newport News, Virginia
    Turn signal wire up to the first plug maybe, came undone? stunnuts is right, we need more pictures, lol.
  5. mlew
    looks like the broken end of the clutch switch, can't really see in the pic. Get a close up and trace where that wire goes.
  6. Darth_Menace
    Darth_Menace Member
    Alberta
    I think it comes out of the huge bundle of the headlight wiring
  7. Darth_Menace
    Darth_Menace Member
    Alberta
    here is another picture
  8. Darth_Menace
    Darth_Menace Member
    Alberta
    and another
  9. stunnuts
    stunnuts Member
    Pierre, SD
    Pretty sure that is the switch wire for the clutch.
  10. Darth_Menace
    Darth_Menace Member
    Alberta
    uh oh. I don't know what that means, but it sure doesn't sound good :)
  11. bigfitz52
    It WAS the switch lead for the clutch switch. Actually, it still is, but the switch it's supposed to be permanently connected to is on the handlebar.
    Read this, it explains everything: http://xjbikes.com/Forums/viewtopic/t=30354.html
    Ya needs a new one.
    (The other end plugs into the flat GREEN connector inside the headlight shell.)
  12. WinstonC
    WinstonC Member
    Sparta, Wisconsin
    Clutch switch. Mine fell off a while ago. Yep, gonna get around 'someday' to fixing that.
  13. mlew
    Yep, clutch switch was my first thought. Give Chacal a PM he will set you up with a new one.
  14. 82secacustom
    82secacustom Member
    Cambridge, Ontario
    What exactly does this switch do anyways?
  15. stunnuts
    stunnuts Member
    Pierre, SD
    The switch keeps you from starting in gear without the clutch pulled in.
  16. Darth_Menace
    Darth_Menace Member
    Alberta
    and will my bike me able to move if it's just like that?
  17. maverickbr77
    maverickbr77 Member
    Lowville, New York
    Makes it so you cant start your bike in gear without pulling the clutch lever.
  18. stunnuts
    stunnuts Member
    Pierre, SD
    If it will start yeah. I think it will start in neutral without the clutch but I'm not sure. If it does then you can ride.
  19. maverickbr77
    maverickbr77 Member
    Lowville, New York
    You will still be able to start in neutral and run the bike fine. The switch can be jumped so the system think the clutch is always pulled. Although it may be a safety risk if you start you bike in gear without pulling the clutch as the bike will run away.
  20. Ledicott96
    Ledicott96 Member
    North west England
    Some sort of issue with my 750 SECA US import (UK bikes do not have that feature) just twisted the wires together so it thinks that the clutch is in all the time. Or you could reconnect it quite an easy job, all so it depends if you trust your neutral light.
  21. bigfitz52
    So, to summarize (because your answer is there, in the posts above, but in bits-n-pieces:)
    It's the clutch lever signal switch.
    It tells the safety circuit that the clutch is in, so that you can:
    Start the bike in gear, (with the clutch pulled in.)
    Your bike will run with it broke and not bypassed; you just won't be able to start it unless it's in neutral. I DO NOT recommend bypassing it; either fix it (best) or leave it disconnected (safer than if bypassed.)
    To fix it you'll need to replace it. They're not expensive.
    Len carries two styles; they are documented in my article that I posted a link to. I just replaced both of mine; one was broken altogether, and my 16-YO son is about to start learning to ride that bike; the other one was falling apart (as described in the article) so I replaced it too.
  22. KiLo
    KiLo New Member
    Hi all I also have a mystery wire. :lol: on my seca 750 its a 4 wire bundle that is under the regulator/rectifier, I just bought this craigslist special and its got No horn at all im guessing thats what its there for, but im not sure.
  23. bigfitz52
    1: A picture is worth 1000 words.
    2: It's not clutch-switch related; so please:
    3: Start a new thread "what is this bundle of wires?" and include a pic.
  24. Darth_Menace
    Darth_Menace Member
    Alberta
    thanks for the help guys. I likely won't get around to this cable for a bit longer as I have to first worry about getting a Lead wire :)
