exhausr heat question
Discussion in 'XJ Technical Chat' started by Campbte, Mar 31, 2011.
  1. Campbte
    Campbte New Member
    Hi there.
    So I've been searching for the average heat produced by a 1981 xj650 maxim exhaust..basically how hot does the pipes get. I am aware of environmental factors but I am looking for atleast a range starting from when the pipes are warm to a good 2 hr slow easy ride later.
    The reason...
    There is a custom slip on that has a hole in it fairly small still runs fine, once its warmed up lol, and am looking for a.temporary quick fix. Welding is an option but id rather avoid any more. I have heard of j.b. weld that is perfect to 600deg and liquid steel.. liquid steel im not sure of the heat tolerance... I doubt 600deg is enough but I could be wrong...
    Thanks in advance
  2. Rickinduncan
    Rickinduncan Member
    Duncan, BC Canada
    I've temporarily fixed ( held for 6 years) a rotten hole in a 84 venture using that stuff that looks like plasticine and you mix it up until it changes colour then you put it on. Then you can file off what you don't want. It never broke or chipped and didn't come off. Heck it might still be on the bike with the new owner. - Rick
  3. Campbte
    Campbte New Member
    Lol awesome on the exhaust? That's my concern course no loss just by trying right! Lol
  4. hardlucktx
    hardlucktx Member
    Allen Texas
    I fixed a hole in a header in one of my hotrods with jb weld and never had a problem.
  5. stevestrom
    stevestrom Member
    You guys have had better luck than me with that stuff then. I used it to patch a hole in the end of the muffler on my other bike (no, not the one that s suppose to be there!). It lasted about 1 week before cracking and flaking off. I had even used small wire mesh to give it more strength and my prep work was extensive.
