Mixed up headers...
Discussion in 'XJ Technical Chat' started by MadCowInk, Apr 18, 2011.
  1. MadCowInk
    MadCowInk Member
    OOPS...took the headers off my 82 XJ750, forgot to mark them. Is there an easy way to figure out wich one goes where besides trial and error? just askin'...
  2. bigfitz52
    Sure is.
    Look VERY CAREFULLY at the pipes; it's usually down right where they join to the collector. Each exhaust pipe has an abbreviated part number on it; on my 550s it says "YAMAHA 4G0-1," "-2," "-3" and "-4." The "dash-1" is the number one pipe, etc. On the 550s it's on the left side of the pipes, your may be in a different location, but if they're stock Yammie pipes the part number is on them somewhere.
  3. MadCowInk
    MadCowInk Member
    Thanks, I checked some online photos and the numbers are located right where you said they would be. Now I just need to undo a few inches of header wrap to read them all...grr...arrgh!
  4. bigfitz52
    Oh, c'mon the little "dash" numbers are't that far from the ends.
    Question about header wrap (just askin' because I can't figure it out) doesn't it GET DIRTY? Like when you get caught in the rain? Then what?
  5. MadCowInk
    MadCowInk Member
    Since we're on the topic, I assume they go back on in order 1,2,3,4 starting on the shifter side?...
  6. MadCowInk
    MadCowInk Member
    the wrap is purely for cosmetic purposes, black wrap, silicone coated...
  7. bigfitz52
    1-4 left to right as you sit on the bike.
    OK, so it's black and silicone coated. Doesn't it have kind of a "fabric" surface? Doesn't it get dirty and then how do you clean it? What happens to the cosmetic value after 6 hours riding in the rain? Does it "weld" together and stick to the pipes?
    I would honestly like to know; the headers on my 650 will never be chrome again and I'm considering all options but I can't see how that stuff can hold up, looks-wise, once dirty.
  8. MadCowInk
    MadCowInk Member
  9. MadCowInk
    MadCowInk Member
    I'll let you know how the wrap holds up. If it ends up as lousy as you say, I can always peel it off and powder coat'em.
  10. bigfitz52
    Re: the number-- yes it is.
    I didn't say it was lousy, I was asking. Powder coat doesn't work (too hot) but Jet Hot Coating does. That's what I'll probably do, since no plater will touch old dual-walled exhaust pipes.
  11. MadCowInk
    MadCowInk Member
    Thanks for the info Fitz.
