clutch advice
Discussion in 'Hangout Lounge' started by seca750, Apr 19, 2011.
  1. seca750
    seca750 Member
    New York
    Hello all! I was looking for any tips before I replace the springs and friction plates in the clutch. I plan on running the bike to get it warmed up, drain the oil then start with the clutch.
    Thanks for any tips!
    SECA750
    P.S.
    Thanks to XJ4Ever for the parts!
  2. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    If it's time for an oil change, go ahead and drain it. But if you've changed the oil recently you can just put the bike on the side stand and remove the clutch cover. If it's not over-filled you shouldn't lose any oil.
    Make sure you saturate all the parts with oil
  3. seca750
    seca750 Member
    New York
    Sweet! Thanks for the tips!
