Stubborn ignition rotor bolt.
Discussion in 'XJ Modifications' started by Thrasher, Apr 17, 2011.
  1. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    Can’t get the ignition rotor bolt off. Tried electric impact, no luck. Tried allen wrench with pry bar, bike in 1st gear brake on and oversize broom stick in between spokes and swing arm. Broke the oversize broom stick. This is not a left handed thread is it?
    I think I will get some help and put a wrench on the flats of the rotor and then try all the above again.
  2. perryfager81
    perryfager81 Member
    Las Vegas
    put a long wrench on the square part and try an impact gun if you have it.
  3. Robert
    Right hand thread Thrasher. I highly recommend an impact tool or gun. Good luck!
  4. Thrasher
    Thrasher Member
    As I said in my first post, Tried electric impact, no luck. I put a 17mm wrench on the flats of the rotor and then used a long breaker bar with a 6mm allen. Came off with a strong pull.
  5. Militant_Buddhist
    Militant_Buddhist Member
    Redmond, WA
    I swear by the impact driver ya hit with a hammer. I wish I could find one that only turned counter clockwise. I use it all the time but NEVER tighten with it. probably spent 8 hours of my life to date checking and double checking to make sure it was set to loosen.
  6. JFStewart
    JFStewart Member
    Ontario Canada
    Impact drivers do reverse. There is a collar on them that should rotate to switch direction. In any case, put the driver on the bolt or screw and twist in the desired direction when striking it, it should work.
