mirror pictures?
Discussion in 'XJ Modifications' started by Darth_Menace, Apr 22, 2011.
  1. Darth_Menace
    Darth_Menace Member
    Alberta
    hey guys, I'm looking to get a set of mirrors. i only had one, but i smashed it when i tipped it. it didnt look good anyways (i think it was the stock one)
    I have been looking at a new set of mirrors, but it's hard to picture what they look like on there. can anyone post pictures so i can get a general idea?
    also, one mirror or two?
  2. Darth_Menace
    Darth_Menace Member
    Alberta
    also, i'm looking for an clamp or whatever they are called so i can get a left side mirror too, but are the handlebars 7/8 or 1 inch?
  3. MiGhost
    MiGhost Well-Known Member
  4. wamaxim
    wamaxim Active Member
    Vancouver, USA
    The handlebars are 7/8 inch. Be sure to get one mirror with reverse threads if you are going to use the stock mounting system. One hole is reverse threaded, the right one I believe, so your mirror will loosen instead of snapping off if you go down.
    You might consider bar end mirrors. Fantastic little idea. They stick right out so you can get a good look at what is beside you and behind you. My favorite are the Napolean Bar End Mirrors.
    Loren
  5. DrPainsaw
    DrPainsaw Member
    victoria bc
    i've always been partial to mirrors under the controls, i think it makes the profile of the bike nicer, you also are under your shoulders so you have a great view of what's behind you. i run one under the left side. http://xjbikes.com/Forums/viewtopic/t=30596.html
  6. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    The stock bars are 7/8"
    If you have the stock MC/mirror mount it is reverse threaded.
    There are a lot of choices in mirrors, you can get round, rectangle, flames, billet, plastic (eww). But whatever you decide to go with, definitely get TWO!
    You may only look in the right side mirror once it a while, although you should train yourself to check both mirrors. Safety first, and if you only use one mirror then you only see half of what's behind you.
  7. bigfitz52
    Mine too. They're still manufactured but have had some import/distribution issues. Worth tracking down, they often come up on eBay. They're a little more expensive than some of the stuff that's out there but the quality is excellent:
  8. Darth_Menace
    Darth_Menace Member
    Alberta
    this is the design i'm thinking
    there is this size, and smaller but the same shape. would this size be sufficient or too honking big? I don't have a clue
  9. Darth_Menace
    Darth_Menace Member
    Alberta
    actually i guess looking at those dimensions they must be the smaller ones. anyways how would those look?
    i also need some clamp thing to make it possible that i have a left handle mirror
  10. darkfibre
    darkfibre Member
    Perth, Australia
  11. MiGhost
    If you look at the pics that Fitz posted. That round post just to the left of the hi/lo switch (in the 1st pic) should have a removable plug. This should be part of your clutch lever mount. That will be your left mirror mount.
    As long as the mirrors give you good visiblity to the rear and side. Then it only leaves personal preference to deal with. One of the easiest ways to add your own personality to your bike. Absolutely go with two mirrors though!
    Ghost
  12. bigfitz52
    Here's the thing with mirrors: Looks are fine but the whole idea is to see behind you. What happens when you change handlebars (something I always do on a Jap bike) is quite often the stock mirrors no longer give you anything but a nice view of your own shoulders.
    So when choosing mirrors, by all means pick some you like, but if it turns out they don't work for you, then keep looking.
    I went through three different sets of mirrors before I tried the Napoleans. One set was decently wide, and gave a good view, but absolutely would not stay adjusted at road speed. The next set worked well also, but was really just too obtrusive, appearance-wise. And so forth.
    The Napoleans are great; seeing around my wide self is no issue, and they are vibration-free and clear as can be at road speed. Highly recommended, if you can find them.
  13. Darth_Menace
    Darth_Menace Member
    Alberta
    that must have cost some mad cash for that aftermarket silver/stainless controls, etc. is that aftermarket for the xj bikes?
  14. Darth_Menace
    Darth_Menace Member
    Alberta
  15. tskaz
    tskaz Active Member
    Have you thought of something like this for the left mount?
    clutch perch
  16. darkfibre
    darkfibre Member
    Perth, Australia
    Switches are from a Yamaha Royal Star, Bought second hand from ebay. For polished aluminium switches they were reasonably priced. Some modifications were required though :roll:
    Most aftermarket perches are RH thread, which is normally not an issue if you are buying aftermarket mirrors, as most come with both options.
  17. Darth_Menace
    Darth_Menace Member
    Alberta
    on another similar note. I'm looking for new handle grips. are these hard to replace, and is the lef 7/8 and the right 1 inch?
  18. MiGhost
    They will both be 7/8.
    As you going beyond the personal customising into the realm of Personalization Check out JPCycle http://www.jpcycles.com/ and start your wishlist.
    Me sees a major project in your future :) !
    Ghost
  19. Darth_Menace
    Darth_Menace Member
    Alberta
    hmmm, anything i have found for yamaha has the left as 7/8 and the right as 1 inch
  20. Darth_Menace
    Darth_Menace Member
    Alberta
    bad post...deleted it
  21. Darth_Menace
    Darth_Menace Member
    Alberta
    Uh oh, I was excited until that "modification" statement came along :)
  22. MiGhost
    It may be and adjustment to fit over the throttle tube. Not sure on this though. Otherwise they should just slide on and off.
    Ghost
  23. tskaz
    tskaz Active Member
    7/8" bars take a 7/8" for the left and 1" for the right to fit over the throttle housing.
  24. Darth_Menace
    Darth_Menace Member
    Alberta
    seriously, what kind o modifying does it take to get these bad boys on? I'm really wanting to know as they look super sexy and dont seem to cost much on ebay
  25. Cooter
    Cooter Member
    Chi-Caw-Go
  26. DrPainsaw
    DrPainsaw Member
    victoria bc
    only downside of those chrome controls is you'll lose your enrichment lever on the left side.
  27. darkfibre
    darkfibre Member
    Perth, Australia
    I had to put 1" sleeves on the bars. Worked out the wiring for the switches then modified the plugs so they were a plug and play on the original harness.
    Where I live you only need a few seconds of enrichment, so I just hold the lever on the side of the carb, instead of having a lever on the bars. Wont even need to do that when the injection is finally all fitted up.
  28. Darth_Menace
    Darth_Menace Member
    Alberta
    hey those are sweet too. the thing is i do need the choke button, so i can't give that up
  29. maverickbr77
    maverickbr77 Member
    Lowville, New York
    Take a look into "pro grips" they have a bunch of styles and for me at least the 601, which is technically a scooter grip, is super comfy. A set came on my brothers nighthawk and I put a set on my 650 and have a set waiting to go on the 750 when I start putting it back together.
    For most aftermarket grips you will need to smooth out the ridges on your throttle tube at least a bit and maybe shorten it so everything meshes up nice, there are a few grips out there that are too long for your throttle tube but not many. If you don't care about the old grips just gently cut them off. To put the new ones on your air compressor is your friend. get the grips started on, then block the far end of where you are installing them, point the air gun into the small hole on the end of the grip and you should be able to slide them on nice and smooth. You can use the same principles to remove a grip if it isn't glued on.
  30. Darth_Menace
    Darth_Menace Member
    Alberta
  31. MoberlyMaxim81
    MoberlyMaxim81 New Member
    Colorado Springs
    It took a tap and die set, adapters, a pipe cutter, and time but I love these Arlen Ness Mirrors so I did it. Also Arlen Ness makes cast stem mirrors that fit directly but I'm stupid and never do things the easy way.
