New Grips
Discussion in 'XJ Modifications' started by killer_chicken, Mar 4, 2007.
  1. killer_chicken
    killer_chicken Member
    Edmonton, AB, CANADA
    This was only a minor modification, but whatever, this weekend I replaced the grips on my bike. The stock rubber ones just didn't cut it for me, so I went looking for what was available. I wanted something that would cut down vibration, as my throttle hand will go numb after 20 minutes or so. I went with Progrip 862's which I ordered from a dealer here for $15 CAD. I haven't had a chance to take it out yet (though I almost did, as it was 10 C yesterday) but I definately like how they look and feel. They are not only nice and squishy, but they have awesome grip (you don't have to squeeze as hard), and they are slightly larger then the stock ones, which I think is more comfortable.
    They went on relatively painlessly, the left side twisted and pried off, the right I had to cut off. The new left side slid on nicely with some WD40, which dried up in half an hour or so, leaving it nice and solid. The right side wasn't so nice, as there were ribs all along the plastic throttle piece. Four of the ribs on the inboard side were larger and I had to trim those off to get the new grip on.
    Anyway, I may update this post when its finally on the road (i'll be driving an hour and a half the first time out). Here are a couple of pictures, if anyone is interested.
  2. Switz1
    Switz1 Member
    Central Illinois
    Cool, I have been looking for some new more comfortable grips, any way to get some more input on what other XJ ers are using? I have the same bike as you Chicken are those one inch in diameter handlebars??
  3. killer_chicken
    7/8" handlebars, the left is 7/8" the right with the plastic is 1"
  4. Altus
    Altus Active Member
    London, Ontario
    I just replaced my second set of grips with these - they're embossed rubber and I chose the aligator skin print:
    Got them from JP Cycles for about $30 US:
    JP Cycles grips
    So far they're wonderful -- easily absorb as much vibration as the "foam n chrome" grips I had on previously, and look a helluva lot better. Feel great too.
  5. a340driver
    a340driver Member
    Langley B.C. Canada
    Did you order them from the dealer killer_chicken?
  6. killer_chicken
    I got them straight from Argyll Motorsports, one of the Yamaha dealers here in town, but they all quoted me around $15 CAD, no shipping costs either, good deal if you ask me. I was looking at some foam grips too (my brother has some on his nighthawk), but I decided to try the gel type and i'm glad I did, my brother is contemplating replacing his now too.
  7. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    Do the chrome endcaps come with the grips? They really dress things up. Looks good!!
  8. killer_chicken
    yes, they were all one piece, chrome included, nice subtle change that makes the bike look good.
  9. Dispatcher
    Dispatcher Member
    New York, USA
    I've been looking at similar grips myself, just can't decide if I want rubber (better grip) or neoprene (less vibration). Also, I noticed that some of the end caps are actually plastic.
  10. killer_chicken
    My endcaps are plastic, but they were only $15, and I don't really care that much, my brother has the same style endcaps that have lasted 8 years and still look good.
    I had a chance to take the bike out this weekend, as it got to a balmy 4 degrees celius, and after riding for around an hour my hands felt fine, as far as i'm concerned, the best $15 i've spent. I would recommend an aftermarket gel/foam set of grips to anyone.
  11. kevineleven
    kevineleven Member
    Columbus, Ohio
    I put yellow ATV grips on mine. Had to lube the throttle real good, but I got 'em on. You can kinda see one here...
  12. Fraps
    Fraps Member
    Kitchener, Ontario, Canada
    I've been toying with the idea of heated grips for those balmy rides to work when it is just above 0 deg celcius. (You know I'm going to do it! Same as you!)
    Any thoughts on how they work? Looks like about $60.
  13. bosozoku
    bosozoku Member
    Albany, Oregon
    Hot Grips are great- put them on ASAP.
    The only problem you'll have is kicking yourself for not having done so a long time ago.
  14. capy
    capy Member
    Florida
  15. samsr
    samsr Member
    Colorado Springs
    Excuse me for being new to the grip thing but do you have to buy two sets then one set 7/8 and another 1 or can you get the 7/8 to slide over the 1 inch plastic throttle? I have been wanting new larger grips. The originals hurt my hands after about 5 to 10 minutes. Come with being a mechanic I guess.
  16. bosozoku
    bosozoku Member
    Albany, Oregon
    Grips come sized to fit the bar diameter on the left and the throttle tube on the right for a bar of that same size.
    Unless you've got Harley-sized bars (1"), just order a 7/8" set.
  17. Polock
    a set of 7/8 grips will have a larger one for the throttle
  18. Impulse2k1
    Impulse2k1 Member
    Illinois
    how hard/easy is it to change the grips?
  19. samsr
    samsr Member
    Colorado Springs
    Thanks guys. Away to the internet I go.
  20. killer_chicken
    Mine were a breeze, but it depends on whether or not you are looking to keep the old grips. I opted to cut mine off, the hardest part was getting an end weight off the left side. I used a copious amount of wd-40 on the inside of the grips, left side slid on no problem. The right has a plastic piece with protrusions, it slid over most of them ok, but on the innermost part were four larger ones that I cut off. Once the WD-40 dried up they felt great, no slipping at all. I had it done in 15 minutes or less.
  21. Hack
    Hack Member
    Ontario, Canada
    This thread was started a while ago, but I just picked up a pair of the 862s for my Maxim. I was surprised to see that there didn't seem to be any difference in diameter between the two sides, at least visually. I am going to install some grip heaters underneath, and am wondering if it would be a good idea to remove the ridges on the throttle sleeve to make the grip fit better, or should I leave well enough alone. I guess the danger in removing the ridges is that the grip could slip on the throttle side, but I would welcome your thoughts.
    Thanks!
  22. Bane
    Bane Member
    Fargo, ND
    I have been using nthese for about three years now. They have a thick cruiser grip and the rubber material (kraton-G) holds up very nice. Highly recommended. The end caps are metal by the way. I paid about $30. Still that same price.
      File size:
      14.8 KB
      2,328
  23. flash1259
    flash1259 Member
    W.R. Wisconsin
    hack
    put the grips in warm water get them in position then let them dry for a day or 2. don't use oil or any kind of lube.
    the warm water will do real good.
  24. bigfitz52
    Since the original Yamaha grips had grooves molded in them to accept the ridges, when I put my GranTourismos on I shaved down the ribs but didn't remove them completely, and cut off the more "aggressive" locating lugs at the end and they work fine.
  25. flash1259
    flash1259 Member
    W.R. Wisconsin
  26. Hack
    Hack Member
    Ontario, Canada
    Thanks for the comments. I took some measurements and the throttle side is just a little larger than the clutch side. Even so, I think I'll take your idea, Bigfitz, and shave the ridges down a bit. It will be a couple of weeks until I get the grip heaters wired and installed, so I was a little ahead of myself with the question. It snowed again today and I want it to be a bit warmer before tackling this part of my winter activities so the mylar elements set up OK.
    I can say that the Pro Grip 862s have a really neat feel to them.
  27. PainterD
    I just noticed this thread-
    I have the grip heaters under my grips (so nice) and I did sand down the ribs on the throttle sleeve so the grip heater units would adhere to them better. I just used warm water inside the grips to slide them onto the handlebars and they fit nice and tight. The water dries eventually and the grips haven't moved in two years now.
    I had some thinner rubber grips on when I first put the grip heaters on, which I thought would make the grips heat more efficiently. I changed the grips to thicker, more comfortable grips since then. The only difference is that it takes a little longer to feel the heat, but they eventually get plenty hot.
  28. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Hey Fraps, do you ever ride through Tavistock?, i could have swore i saw an XJ drive through a couple times last summer.
  29. Hack
    Hack Member
    Ontario, Canada
    Got my 862s on the bike last weekend. I installed grip heaters underneath.
    I found it necessary to take off the collars on the switch side of the grips. They don't look quite as nice, but I couldn't seem to get them on otherwise. For some reason I didn't sand down the ridges. Really should have as it would have made things much easier.
    Took it for a ride yesterday and they felt great.
  30. Altus
    Altus Active Member
    London, Ontario
    Might have been me actually :D
    I usually go that way when I'm heading for K/W
  31. earz_cd
    earz_cd Member
    Jefferson city, MO
    I'd rock these if they made them in 7/8". The sparkly ones!!!
  32. PainterD
    I have the "Coke bottle" grips on mine (not that brand) and they are very comfortable on the hands. There are literally thousands of 7/8" grips out there to choose from. From $5 all the way up to $150, it's all in what trips your trigger and how much you want to spend.
  33. photoxj
    photoxj New Member
    Grip Trick, I found putting grips on was quite tough, so I oiled the inside and they slide right one...
    ...HA! kidding, actually this is a trick from my downhill mountain bike days. To get grips on and off use an alcohol based hairspray. It'll dry and make them sticky, but when it's wet it'll let them slide on/off quite easy.
