in need of serious help
Discussion in 'XJ Technical Chat' started by jmarks81yammie, Jul 18, 2011.
  1. jmarks81yammie
    jmarks81yammie New Member
    bought an 81 750 seca witb the yics motor. need wiring diagram for the whole bike front to back. when i bought the bike every single plugin was cut off cant get ne thjng to ne where. if some one has the diagram please help me out. thanks
  2. 213chrisp
    213chrisp Member
    Dayton ohio
  3. jmarks81yammie
    i dont want ti buy a new harness i just want to fix this one to be able to ride so really wat ik askin is for a wiring diagram
  4. bigfitz52
    That's not going to help; OP has an '81 Seca 750; the harness is from a much later FJ600. Even though the numbskull eBay seller claims it will "fit" an XJ750, it's wrong.
    jmarks81yammie what you need is a factory 750R book; it has not only the wiring and circuit diagrams but cable routing and component location diagrams you won't find in the Haynes.
  5. 213chrisp
    213chrisp Member
    Dayton ohio
    ahh, just assumed if it was that hacked up, and if the cost was about right, then be simplier and easier to just start all over with.
  6. jmarks81yammie
    the plugins arent cut ofr the controls just the plugijs off the tci and the harness ijside the head light srry should have veen more specific
  7. badfish502
    badfish502 Member
    ok
  8. jmarks81yammie
    and for the back half
  9. badfish502
    badfish502 Member
    heres the diagrams i used.
  10. jmarks81yammie
    thanks so much man i appriciate it so much
  11. Militant_Buddhist
    Militant_Buddhist Member
    Redmond, WA
    the Yamaha Factory book for the 750R has errors. For wiring you want the haynes book
  12. iandmac
    iandmac Member
    Brisbane Australia
    If you know the details of errors in the 750R diagrams, please post them so we can edit the diagrams and post them for others. So far I haven't found any differences on my 750, only a couple of minor issues on the 900.
  13. jmarks81yammie
    can someone send me he diagrams bigger cant zoom gets to blurry
  14. iandmac
    iandmac Member
    Brisbane Australia
    PM'd you, please check your inbox
  15. Smooooth
    Smooooth Member
    Syracuse, NY
    My I please have a set also??
    The ones on the XJCD do get a little blurry.
    And now I find myself tracking down a 'TAIL' warning.
    Thank You
    Stephen
  16. TIMEtoRIDE
    jmarks81yammie - - My Seca 750 came with blue wire splices, a cut and abraded area under the tank, tape, missing wires, non-working starter and signals, and a hacked fuse box. . .
    I bought an E-Bay harness for $15, threaded it in and EVERYTHING was fixed !! Easy. I highly recommend you do the same. Even if you had to pay $75.
