78 Yam RD400 tank
Discussion in 'XJ Modifications' started by RobDrech, Jul 23, 2011.
  1. RobDrech
    RobDrech Member
    Middletown, CT
    Will this fit the triple backbone on the 80 xj650? I love the look of the tank and if the front mounts fit, it would be a sweet tank!
  2. RobDrech
    RobDrech Member
    Middletown, CT
    Nobody has any ideas?
  3. RobDrech
    RobDrech Member
    Middletown, CT
    Or what about this tank???
  4. silverdollar
    silverdollar Member
    Chesapeake, VA
    I like the look of the tank. Where did you get it from and what was the cost?
    I have a 83 Maxim 650 and I am thinking really hard about another tank as well. Also conceder the petcock. Where is the petcock located on this tank?
    I know on the Maxim the bars in which the tank rest upon is more of a 45 degree angle. With that tank will it be level?
  5. silverdollar
    silverdollar Member
    Chesapeake, VA
  6. RobDrech
    RobDrech Member
    Middletown, CT
    Which tank?...
    I don't own either, I'm trying to source parts to build a cafe racer and wanted to see if anyone has anything to add or help.
  7. SgtHollywood
    SgtHollywood Member
    NYC
    Get a photo of the channel and request measurements. Compare with stock XJ. Worse case get a hammer an cutting wheel, some sheet metal and a welder and make it fit.
    It's not super easy but not too hard either. I just did this with a small channel tank to mount on an SR 500.
  8. silverdollar
    silverdollar Member
    Chesapeake, VA
    I was talking about the white tank in the photo above.
