Looking for a helper
Discussion in 'XJ Technical Chat' started by TFD56, Jul 25, 2011.
  1. TFD56
    TFD56 Member
    Tiverton, RI
    I consider myself to be mechanically inclined yet I'm nervous about my most recent issue. I'm fairly confident that I had a failure of the Primary Chain Guide. I was pulling away from the stop light in front of my fire station and I couldn't get the bike out of 1st gear. I am fairly confident that the chain guide is my issue. I sucessfully cleaned my carbs a few weeks ago after I checked valve clearances and did a running sync of the carbs. I was so proud of myself. I rode the bike around for a little over a week and now this. The bike is parked in the garage at work until I go get it with my fathers truck. I'll probably go get it tomorrow. I'm a little nervous about splitting the case to get to the chain guide. I've never attempted anything this in depth before. Any tips, hints or ideas?
  2. wizard
    Sometimes just a piece of the guide breaks off & gets into the selector forks, so it might be just whip the case off & remove the piece of plastic, I know this has happened to some of the members, you might get lucky.
  3. TFD56
    TFD56 Member
    Tiverton, RI
    If I pull the cover and remove the piece that's stuck (hopefully) how long am I flirting with disaster before the rest of the guide self destructs and the chain tears a hole in the engine case? I know...it probably sounds a little drastic but I absolutely love my XJ and I don't really want to see it come to that. Honestly, if I pull the side cover and there is a visible piece of the chain guide, I'm only going to risk riding the bike the 2.3 miles home and then it's going to sit until I can get the parts from chacal and tear it down. I hate the thought of not repairing the issue and riding around with it in the back of my mind.
  4. wizard
    A tickleish question, but that is quite a major tear down, I think you can leave the jugs & head in place, get the mill out of the frame & invert it.
  5. Polock
    there's a little pipe that takes oil to the alternator bearing that gets beat up if the guide goes altogether, i doubt the chain would ever break or go through the case
  6. TFD56
    TFD56 Member
    Tiverton, RI
    I pulled the side of the case that the shifter is on while the motor was still in the bike. I looked through the top oil gallery and there it was. a chunk of hard plastic with metal tabs that look like they held it to the rest of the chain guide. I now know without a shadow of a doubt what my problem is. I buttoned the case back up and it shifts fine, sounds fine, runs fine. I'm going to take it easy and drive it home this afternoon when I get out of work. I have allready got the information for the parts that I need to do the jobof replacing the guide and I plan on ordering them later this afternoon or tomorrow. I can't tell you guys how glad I am that this website helped me diagnose my xj and make me a happy guy!
  7. wizard
    Check the starter clutch body for wear & CRACKS, never a better time to replace that sucker.
  8. TFD56
    TFD56 Member
    Tiverton, RI
    what makes the starter clutch so suseptable to failure? Is it also made of plastic like the primary chain guide? I don't have the bike torn apart yet. I am waiting for a few days off in a row to start the process. Then I plan on making a list of what I need and getting ahold of chacal with my order.
  9. wizard
    No, it's made of bronze or something like it & it has week spots.
  10. TFD56
    TFD56 Member
    Tiverton, RI
    I appreciate all the input. I will be splitting the case this afternoon and I will let everybody know how I make out and what I fuind when I get in there. Wish me luck
