cam swap and stroker crank needed
Discussion in 'XJ Modifications' started by ajgreider, Aug 20, 2011.
  1. ajgreider
    ajgreider New Member
    does anyone know of performance cams for the 400 or a crank for a stroker setup and does any of the 500 sereies motors parts fit the 400 block
  2. ajgreider
    sorry for the typos im am not a wiz on the keyboard just wrenches
  3. Kickaha
    New Zealand
    XJ400? easier to buy a 550 or 600 motor and bolt it in assuming they run the same frame
  4. bigfitz52
    If it's the 4-cylinder XJ400 (4G0) they are essentially the same as the 550 Secas.
    An engine swap would be much easier.
  5. ajgreider
    i have thought of the engine swap and if that was done i would want to bore and strock that motor as welll but from what i can tell the 400 lower block and the 550 lower block are the same
  6. TIMEtoRIDE
    Get a load of THIS
    "Wing cut" and balanced crank, higher compression, bigger and different carbs, go get an E-Bay 600 motor to start with.
