Torque Question
Discussion in 'XJ Technical Chat' started by barehandspank, Jul 1, 2009.
  1. barehandspank
    barehandspank Member
    Asheville, NC
    I can't seem to find the correct torque settings for the 4 bolts on the drive shaft flange - anyone out there know offhand???
  2. wizard
    You can always use the general torque settings for each dia' bolt / nut.
    6mm ------7-10 lbf ft
    8mm-------17-22
    10mm-------22-29
  3. silverdollar
    silverdollar Member
    Chesapeake, VA
    Wizard, thank a lot. I could not find them in the Haynes manual as well.
    If it comes off I know where to find you, lol.
  4. Polock
    31.8 ft/lbs
  5. silverdollar
    silverdollar Member
    Chesapeake, VA
    Thanks, I'll be heading back to the garage to thorque somemore. Better now than later, lol.
