gasoline in my bottom end
Discussion in 'XJ Technical Chat' started by xjcharliexj, Oct 11, 2011.
  1. xjcharliexj
    xjcharliexj New Member
    nashville, tn
    Hello, my name is chuck..
    I keep getting a lot of gas in my oil.. what is the cause..? It happened a few weeks ago and I changed my oil and I was fine... but it did it again..I drive my bike everyday... any good ideas?
  2. gark32
    gark32 New Member
    South Jersey
    that generally means that your petcock isn't stopping flow, which lets liquid gasoline into your cylinders and past the rings. if you set it to anything that isn't 'prime' and fuel still flows, rebuild or replace it. if you're running it on prime, something else is wrong.
  3. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Carbs are not sealing and gas is pouring down into the cylinders. Pull the carbs and over haul them ASAP before the gas swells your seals and really causes problems.
    MN
  4. gark32
    gark32 New Member
    South Jersey
    or that. i had seen the issue being caused by a petcock, but i'm really not an expert on bikes.
  5. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    Two conditions must be present for this to happen.
    1. Free flowing fuel from the petcock. Either from being left on PRI, or from a faulty petcock seal.
    AND
    2. A carb float/floats not sealing ("stuck") allowing the free flowing fuel into the cylinders and down past the rings.
    OR
    2. Incorrect float hight adjjustment.
    Petcock test is easy. Just pull the fuel line and test the petcock in the PRI ON and RES positions
    Either way, time to dig into the carbs.
  6. xjcharliexj
    nashville, tn
    Thanks for the tips, I will start with the petcock and ill let you know where that goes?
  7. bigfitz52
    You missed the point. Even if the petcock is allowing flow when it shouldn't, the FLOAT VALVES in the CARBS should shut off that flow.
    You FOR SURE have a carb float/float valve issue;
    you MIGHT have a petcock issue. Gas in the oil is a two-pronged problem; but the float valves are culprit #1. If they were doing their job, you could theoretically leave the petcock on PRI all the time (not recommended.)
    Sorry but you need to start with the carbs.
  8. darkfibre
    darkfibre Member
    Perth, Australia
    ^^^ This.
    If you do a carbs in place float level check (using the hose method suggested elsewhere on here) You should even work out which carb has the problem.
  9. MN-Maxims
    Saint Paul, MN
    Bottom Line
    ***** REBUILD PETCOCK & OVERHAUL CARBS ***********
    THEN
    Set your valves and sync the carbs then you are done
    MN
  10. TIMEtoRIDE
    If you need to keep riding everyday - install a $5.00 Briggs&Stratton fuel cut-off as your temporary fix to get you to the weekend.
    Welcome to the site !!
  11. Ltdave
    Ltdave Member
    not the first time ive heard of gass in the ass...
    had to do it. really.....
  12. tskaz
    tskaz Active Member
    OK, Dave, got a pretty good chuckle out of that one.
  13. xjcharliexj
    nashville, tn
    Well I'm about to dive into the cards.. I printed off the 45 page carborator bible. Hoping that will help me from screwing to much up.. ha ha..
