81 550 won't shut off
Discussion in 'XJ Technical Chat' started by BlackMax, Jan 22, 2012.
  1. BlackMax
    BlackMax Member
    Brampton Ontario
    when i turn off the key,nothing happens,it stays running and no head light at all.
  2. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    Sounds like a worn ignition switch.
    Can you pull the key out without moving it to the "off" position?
  3. BlackMax
    BlackMax Member
    Brampton Ontario
  4. FJ111200
    Looks like that's the problem.
  5. MercuryMan
    MercuryMan Active Member
    Springdale, NWA
  6. bigfitz52
    It just wants you to get back on and ride until it's happy, then it will turn off. :wink:
    Seriously, it probably is the ignition switch itself. If not, you've got some relay wiring crossed up somewhere.
  7. MercuryMan
    Springdale, NWA
    Hehe, it's like the car from Steven King's book, Christine. It's ALIVE! 'You're not done riding me yet-get back on we must go find another twisty road to devour.'
  8. BlackMax
    BlackMax Member
    Brampton Ontario
    Thanks guys, I'm gonna replace the ignition switch with an aftermarket one.Should have it by Saturday!! I'll post the results!!
  9. BlackMax
    BlackMax Member
    Brampton Ontario
    My part didn't come in today but I removed the old ignition,Much to my surprise the bike will still turn over when I hit the starter button.Bad kill switch maybe?
  10. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
  11. BlackMax
    BlackMax Member
    Brampton Ontario
    Plug looks ok,I'm thinking its either a bad relay or the kill switch.....
  12. BlackMax
    BlackMax Member
    Brampton Ontario
    Ok found the problem(s)
    One of the wires connected to the cutoff relay was corroded, cleaned it up and it shuts off fine.The old fuse panel was still in it so I went to Canadian Tire and found an EXACT replica of the old one for five bucks .So i installed it and now no more loose fuses!!! And it looks stock still.....
