Parting xj550 SECA (Rectifier $20/collector $30/Wheel $20...
Discussion in 'For Sale, Trade/Swap, Wanted' started by 750MaximSeattle, Feb 1, 2012.
  1. 750MaximSeattle
    750MaximSeattle Active Member
    Seattle, WA
    See updated CL ad with photos: http://seattle.craigslist.org/sno/mcy/3750459484.html
    NOTE: if you previously viewed that CL link, refresh your browser to view updated text/photos.
    Or, scroll down a couple posts for current list of available parts.
    Will ship. PayPal preferred.
  2. bigfitz52
    Re: Anyone need xj550 Seca parts? Tank, fairing, fenders, etc?
    You shoulda scrolled the forum.
    This poor SOB is tearing his hair out looking for a 550 Seca tank; and I'm not giving up my (dented) spare.
    Hook the guy up, willya? http://xjbikes.com/Forums/viewtopic/t=35274.html
  3. 750MaximSeattle
    Seattle, WA
    Actually, I did see that thread prior to posting this one. Seems that Midias supplied him with a tank. Thanks tho.
  4. 750MaximSeattle
    Seattle, WA
    Re: Parting xj550 SECA
    (UPDATED) Parts from a 1982 xj550 Seca:
    Rectifier - $20
    exhaust collector (good cond.) - $30
    Rear wheel w/sprocket - $20
    Rear brakes - $10
    Swing arm - $20
    Triple tree - $20
    Steering bolt cover - $10
    Handle bar clamp bolt covers (4) - $1
    Dual horns (one works the other does not) - $10/pair
    Tach cable - $20
    Front axle - $5
    Rear axle - $5
    Seat w/o latch - $20
    Battery box - $5
    Battery cover - $5
    Rear brake lever - $10
    Rear brake switch w/spring - $3
    Side stand - $10
    Chain drive gear (#3816) - $15
    Rear foot pegs (L&R) - $15
    Here are ENGINE/TRANSMISSION specific parts:
    Note: engine had 46k miles
    Valve cover w/rubber seal - $15
    Head w/gasket - $30
    (2) Pistons w/rods - $20 for 1 or $25 for 2
    Tranny gears & shift forks & clutch basket - $40
    Shifting actuator - $15
    Oil pan - $25
    Oil drain plug - $5
    Misc. bolts - request what you need and make offer
    Every part was harvested, too much to list.
    Make offer on parts that are not listed above or sold (below).
    Hi-rez pictures available upon request.
    Here's what's SOLD or PENDING:
    Exhaust brackets (L&R) - $15 (SOLD)
    Speedo cable - $15 (SOLD)
    Speed sensor (hub) - $5 (SOLD)
    LH controls (signals/lights/horn) - $15 (GONE)
    Rear fender - $10 (GONE)
    Tail section - $20 (SOLD)
    Tail light assembly w/lic plate holder - $30 (SOLD)
    Crank - Free (GONE)
    CDI (igniter) T1D15-05 4U8-10 - $40 (SOLD)
    Coil for cylinder #1 & #2 - $10 (SOLD)
    Ignition Timing Pick Up Assembly $22 (SOLD)
    Pistons - $25 (2 of 4 SOLD)
    Rear brake switch - $5 (GONE)
    Neutral safety sensor - $15 (SOLD)
    (4) intake manifolds - $20 (GONE)
    Starter solenoid - $5 (SOLD)
    Handle bars - $20 (SOLD)
    Head light assembly w/brackets - $20 (SOLD)
    Chain guard - $10 (SOLD
    Chain adjusters (2) - $5 (SOLD)
    Brake master cylinder - $20 (SOLD)
    Front brake switch $5 - (SOLD)
    Carbs - $50 (SOLD)
    Coil for cylinder #3 & #4 - $10 (SOLD)
    Alternator stator - $15 (SOLD)
    Alternator rotor - $15 (SOLD)
    Forks - $20 (SOLD)
    Front brake line separate - $15 (SOLD)
    Front brake caliper w/pads - $30 (SOLD)
    Front signals (both) - $25 (SOLD)
    Rear signals (both) - $10 (SOLD)
    Instrument cluster - $40 (SOLD)
    Wire harness $10 - (SOLD)
    Tool kit - $20 (SOLD)
    Center stand FREE (GONE)
    Fairing w/brackets & shield - $50 (SOLD)
    Front fender - $10 (SOLD)
    Starter motor - $30 (SOLD)
    (4) Headers FREE (GONE)
    Mirrors FREE (GONE)
    Seat latch - $10 (SOLD)
    LH muffler (fair cond.) FREE (GONE)
    RH muffler (damaged) FREE (GONE)
    Front wheel w/disc separate - $20 (SOLD)
    Tank w/sending unit & cap (minus lock) - $90 (SOLD)
    YAMAHA set of 2 matching keys with ignition switch, tank cap & lock, helmet lock, seat latch lock, & chain lock for wheel all for - $50 (SOLD)
  5. zombiehouse
    zombiehouse Member
    Pomona, Ca
    Re: Parting xj550 SECA (tank $90...)
    PM'd you about front fender. I would like the mirrors too.
  6. 750MaximSeattle
    Seattle, WA
    Mirrors are yours! I'll recalculate total weight for actual shipping cost.
  7. zombiehouse
    zombiehouse Member
    Pomona, Ca
    Saw the PM before this post. As soon as you have the revised shipping cost I will send you the money.
  8. 750MaximSeattle
    Seattle, WA
  9. zombiehouse
    zombiehouse Member
    Pomona, Ca
    Re: Parting xj550 SECA (carbs, collector, lights, tail...)
    I got my parts today. Thank you so much. I really appreciate it.
  10. 750MaximSeattle
    Seattle, WA
  11. bcroach78
    bcroach78 Member
    Fl
    Any tears on the seat?
    I would like
    Seat
    Carbs
    Brake lever Clutch lever (I didnt see this on the list but if you have it, I need it).
    All items shipped to Clarksville, TN 37040
  12. 750MaximSeattle
    Seattle, WA
    SEAT is torn-up, foam is good - $20
    CARBS are good - $50
    BRAKE LEVER:
    front is bent (could be heated & bent back?) - FREE
    Rear is good - $10
    CLUTCH LEVER is good, it's aftermarket and shorter than stock - $5
    If you happen to need the clutch lever perch - $5
    If you happen to need the front or rear brake light switches - $5 each
    If you want pics, go to my profile and make request by sending me an email.
  13. fatabebabe
    fatabebabe New Member
    PM'd you about the rear signals
  14. mauric8311
    mauric8311 New Member
    Re: Parting xj550 SECA (collector/lights/tail/clutch basket...)
    pm sent
  15. eram
    eram New Member
    e-mail sent through CL :)
  16. mauric8311
    Email sent
  17. 750MaximSeattle
    Seattle, WA
  18. Tswami
    Tswami New Member
    Re: Parting xj550 SECA (CDI $40/collector $30/manifolds $20/
    Do you still have the side covers? Couldn't see the CL ads is it white or black? Thanks
  19. 750MaximSeattle
    Seattle, WA
    Sorry, no side covers.
  20. 750MaximSeattle
    Seattle, WA
  21. mangchock
    mangchock New Member
    Yuba City, CA
    do you have the air box still?
  22. 750MaximSeattle
    Seattle, WA
    Sorry, the air box ix gone. If you need a lid, I have one off an xj650. However, IDK if it's the same part as xj550 Seca.
  23. yamamann
    yamamann Member
    Barrie, Ontario, C A N A D A
    how could stand parting this classic ?
  24. 750MaximSeattle
    Seattle, WA
    It was a lost cause with a lost title. Not worth restoring but its parts helped restore other 550 Secas.
  25. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    Do you still have the seat hinges?
  26. 750MaximSeattle
    Seattle, WA
    Yes. $5 for both hinges. PM me with your zip and I'll figure shipping for a total.
  27. Trumpetrhapsody
    Trumpetrhapsody Member
    Fayetteville, AR
    You don't have the gauges, do you?
  28. 750MaximSeattle
    Seattle, WA
    Sorry, no gauges.
  29. 750MaximSeattle
    Seattle, WA
