Amsoil (?)
Discussion in 'XJ Technical Chat' started by tabaka45, Mar 16, 2012.
  1. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Planning on changing oil this weekend. '85 xj700n. Have Amsoil 10w40 motorcycle synthetic oil. Anyone have experience with this synthetic?
  2. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    IMO, any synthetic is not worth the $...
  3. Groundswell17
    Groundswell17 Member
    Maryland, US
    I don't know anything about your bike, but if it has the same style of starter clutch that my 81 xj750 does, don't do it!. From what i've seen and read synthetics can screw havoc with a lot of stuff in these old bikes, starter clutch included.
  4. lostboy2
    lostboy2 Member
    Crimora, Va
    I wouldn't do it either. They didn't come with synthetic oil in them so I would go back with a regular motorcycle oil in it. Just my opinion.
  5. Rickinduncan
    Rickinduncan Member
    Duncan, BC Canada
    Every motorcycle forum I belong to has an amsoil thread. please let this one be short
  6. tabaka45
    Brunswick, Georgia
    so, what kind of oil do you recommend? I don't have the owner's manual, but I assume it still needs to be a motorcycle oil and not regular auto oil. Is that not correct?
  7. brtsvg
    brtsvg Member
    Davenport, IA
    Shell Rotella T6 full synthetic, 1 gal blue jug at Big Wally for $ 21
  8. mooch
    mooch Member
    Dayton, Ohio
    I use yamalube 20/50 in the summer months.
  9. mwhite74
    mwhite74 Member
    Some guys run synthetic, but from my experience anything but Dino oil on XJ clutches spells slippage.
    I use 20w50 castrol (not gtx), and planning on sticking with it. You have been warned :)
  10. hendo68
    hendo68 Member
    Tremont IL
    i use 20w-50 valvolene motorcycle oil.
  11. autosdafe
    autosdafe Member
    Lorain OH
    Automotive oil contains additives that our wet clutches.just plain don't like. Lots of slippage. Stick with motorcycle oil. Every brand is a little different but as long as its motorcycle oil your doing fine. 20w50 I believe is the standard with a lot of these bikes nowadays but the manual calls for 20w40 yamalube.
  12. oilheadron
    oilheadron Member
    Athens, AL
    Motorcycle-specific Amsoil has been working great for us for years now in all kinds of bikes (I own a shop). From scooters to Turbo Busas. Clutch slippage has never been an issue, but I do believe that a weak starter clutch (whether due to wear or simply a weak design like some Yamaha Viragos) may be a little "cranky" on synthetics :D .
    A friend here is the crew chief for one of the most successful motorcycle roadrace teams in the country. When they made the transition to synthetics years ago he said that engine wear became a nonissue overnight.
    Bottom line, if you want the very best engine/transmission protection (and your starter clutch doesn't complain :lol: ), run motorcycle-specific synthetics.
  13. redsix
    redsix Member
    Western Pennsylvania
    +1 to 20w-50 Valvolene motorcycle oil.
  14. jathomas42
    jathomas42 New Member
    Houston, TX
    First post, so be kind:
    Original owner of seca 650. Resurrected 5 years ago and ran dino oil for 3 years. Changed a lot of seals, but then 1 yr ago tried amsoil 20W/50 MC oil with HiFlo Filtro and Lockhart cooler installed at purchase in 1982. Within 2 months, engine ran better than it ever had 30 years earlier. Revs up quickly, vibration nonexistent, no noticeable viscosity breakdown at 3000 miles like dino oils. Extremely happy. Will probably continue to use indefinitely.
    Just my .02
  15. Sabre
    Sabre Member
    Lansing, MI
    Amsoil made my starter clutch slip so bad I was lucky to get the thing started. I'd live to use it because I think it's a superior oil, but I guess I can't.
  16. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    As Oilheadron pointed out the synthetics may not affect the drive clutch, but they can and do play hell with the starter clutch. This is where we want metal to metal contact because that's how it was designed.
  17. adrian1
    adrian1 Active Member
  18. jathomas42
    Houston, TX
    Have also had some starter clutch issues from time to time, but can't attribute them unequivocally to oil being used. You may be right, but it hasn't been a clear association in my bike. Thanks for sharing. Will be more aware going forward.
