Okay now I'm just frustrated.....
Discussion in 'XJ Modifications' started by SuperSeca44, Jul 17, 2012.
  1. SuperSeca44
    SuperSeca44 New Member
    Seattle, WA
    In my last Post I mentioned that oil was spewing out all over my rear tire from my breather hose.... I was told to put a small pod on the end and rout it up in between my carbs. That works..... For about 10 min:( I'm starting to think that the best option is to revert back to the stock airbox?? Will that fix my oil problem for good?!?!?!?!?!?!?
  2. tcoop
    tcoop Active Member
    South Weber, Utah
    I didn't read your other post so I don't know what you've done or what has been suggested...but it sounds like you have too much oil in the crank case, either by putting too much in or fuel getting in there. Putting the air box back in will just start filling the air box with oil. Put you bike on the center stand (or have someone hold it up strait) let it sit for a few min and look at the oil level sight glass to see if you have too much oil. You should see a bubble at the top of the glass.
  3. SuperSeca44
    Seattle, WA
    The only problem there is that the glass is too foggy to tell, but what your saying is if there is too much oil it will eventually stop once it's at the right oil level?
  4. wizard
    Maybe the rings are worn & the crankcase is getting pressurized.
  5. Wrench26
    Wrench26 Member
    Fort belvoir, VA
    its either wizards idea or your too full...
  6. SuperSeca44
    Seattle, WA
    How do I find out which one it is?
  7. k-moe
    Drain your oil and measure how much comes out.
    DON'T use the wife/ GF's measuring cups.....just don't.
  8. mwhite74
    mwhite74 Member
    You'll have to dump the oil and start fresh (fill so you can see the level on the sight glass.
    Have you wet set your carb floats yet? How's the compression? How many miles on it?
  9. SuperSeca44
    Seattle, WA
    I don't know how to set the floats or check the compression, and it has about 30,000 miles on it
