Help Me please I am an Aussie with little knowledge
Discussion in 'XJ Technical Chat' started by beerhound, Jul 21, 2012.
  1. beerhound
    beerhound Member
    Queensland Australia
    :oops: probably not the right place for this but after searching high and low for info on my new project nothing. Here is my problem I live in Australia and yes before you all start G'day mate , do u have a shrimp on the barbie . Well no I don't because Barbie is 2 attatched 2 Ken and if I go over there sniffin here shrimp all hell will break loose, now back to my problem can your 650 maxim 1980 model crank case cover fit my Australian xj 650 crank case cover thanks in advance beerhound :oops:
  2. darkfibre
    darkfibre Member
    Perth, Australia
    I would just like to take this opportunity to say that beerhound is not your typical Australian, he would be more your typical Queenslander.
    C'mon mate, search for the part numbers and then compare them to see if they are the same as the US ones.
  3. ken007
    ken007 Member
    Brisbane, Australia
    gday, this is my 81 650 special which i have found to be the same as the US maxim, many things from the seca dont fit them like cables,side covers etc, i have to get most parts from overseas as my local yam dealer hasnt even got the right micro fish and is dear as poison, typical cost for a tappet cover gasket here is $91 ,from the US i get them for around $25 each delivered in lots of 3.
  4. ol_750
    ol_750 Member
    Newcastle Australia
    8) If you give me the part number I'll run it through a cross referenc program & can let you know what models fit.
    or
    go through XJForever he has info on cross over parts.
    http://xjbikes.com/Forums/viewtopic/t=1 ... art=0.html
    :lol:
  5. beerhound
    beerhound Member
    This is what I need to know if it can be swapped with the 650 maxim as for part no. where do i find this all it has on the cover is 22N00-2R :? :? :?
  6. darkfibre
    darkfibre Member
    Perth, Australia
    The XJ4Ever catalog (listed in the for sale section) says:
    So it should fit, but the style may look a little different.
  7. beerhound
    beerhound Member
    :D :D :D :D Thanking you sir will order both left and right :D :D :D :D
  8. wizard
    Do it yourself kit. YAMAHA
  9. beerhound
    beerhound Member
    :cry: :cry: :cry: 4H7-15416-00-00 COVER, OIL PUMP Not Available :oops: :oops: :oops:
  10. wizard
    You just use that site for the part numbers, you wouldn't actually buy anything from the stealership.
  11. beerhound
    beerhound Member
    Thanks will do
  12. ken007
    ken007 Member
    Brisbane, Australia
    ebay US haS heaps of bits and pieces, but many use the postage to australia as a 2nd income stream, unfortuneately
  13. beerhound
    beerhound Member
    Yes have noticed this but a good thing I have mates in the security industry over there hopefully they will look after me
  14. adrian1
    adrian1 Active Member
    Just wait a while.....I'll bet you have a whole heap more stuff from xj4ever you'll need. Get it all together then place one big order! Welcome to the site and go the Maroons.
  15. TIMEtoRIDE
    This (pictured) broken side cover is from a 900 anyway, it's not a "non-YICS," smooth side cover ( one cast piece).
    Check Ebay-AU, and keep looking, meanwhile keep riding !!
  16. beerhound
    beerhound Member
    :oops: :oops: :oops: Back again another dumb question but I am new to this so here we go in the pic below what is missing in the red square cheers in advance
  17. Bushy
    Bushy Active Member
  18. beerhound
    beerhound Member
  19. beerhound
    beerhound Member
