Indicator flasher/relay question
Discussion in 'XJ Technical Chat' started by crow, Aug 9, 2012.
  1. crow
    crow Member
    Melbourne, Australia
    Just wondering if any of the Aussie riders here could help with a electronic flasher type that I could replace my original with?
    A part/model number would be great so that I could go to Supercheap, Repco etc to pick one up.
    My electrics are a XJ900 setup with separate flasher and cancelling unit.
  2. crow
    crow Member
    Ended with this one:
  3. crow
    crow Member
    Next problem: I have these aftermarket lights to put on the front. Running 10w bulbs.
    Test off the bike - lights OK
    Test attached to bike electrics but not fitted works
    Test attached to bike electrics and fitted into faring frame - Blows fuse.
    I've checked the wiring and used liquid electrical tape on the little bit of exposed wire near soldering but am a little stumped.
    If I use the original flasher relay I get no lights, a quick buzzing sound from the relay but no blown fuse.
    If I run without front indicators connected rear indicators work OK.
  4. Polock
    fitted to frame, blows fuse......reverse the wires.
    or only use one wire (+) to the bulb and let the housing be the negative connection
  5. crow
    crow Member
    You know sometimes you just need that extra set of eyes! Thanks Polock. As soon as I read your post I did a big Homer Doh!
    Amazing that I just assumed the wiring on the indicator lens would be the same as the bike lol.
    Thanks mate :)
  6. readlee
    readlee New Member
    Twickenham
    FYI I managed to fit a CF13 3 pin to my xj750. Brown is + and connects to B+ pin, the Brown/White is your BULB side which connects to L pin. Lastly, you need to connect E- to the frame or and earth wire. You can leave the Yellow/Green wire, which is your auto off trigger.
