fork oil amount
Discussion in 'XJ Technical Chat' started by samsr, Apr 27, 2007.
  1. samsr
    samsr Member
    Colorado Springs
    I am rebuilding my front forks on the xj700 and would like to know how much oil goes into the forks. Forks were nasty inside, but not too much wear. Just need to know the amount. Thanks
  2. WeAreZilla
    WeAreZilla Member
    Yellow Submarine
    The Yamaha factory service manual specs it at 389cc, or 13.7 Imp oz, or 13.2 US oz.
    10Wt Yamaha Fork & Shock Oil or equivalent fork oil.
    Z
  3. englishsandwich
    englishsandwich Member
    South Bend, Indiana
    Haynes says you can go cheapy and use 10w-30 too.
  4. WeAreZilla
    WeAreZilla Member
    Yellow Submarine
    This option may be possible, but it's far from desirable. Fork oil is available in different weights, though, for different damping dynamics. Fork oil has much better properties relating to foaming, shear rate, and consistency in damping properties.
    Another strong argument for the proper use of fork oil is in its Viscosity Index (VI) The VI reflects the relationship of a lubricant's viscosity at a given temperature. Higher VI is better:
    -- Standard motor oil: 110-120
    -- Premium synthetic motor oil: 150-160
    -- Fork & shock oil: 200+
    FWIW.
    Z
  5. ridz
    ridz Member
    Ride hard and live free!
    you can use 15wt also right? and if you do do you put the same amount in?
    Also where is the best place to buy the oil? thanx ridz
  6. WeAreZilla
    WeAreZilla Member
    Yellow Submarine
    It's always the same amount, regardless of weight. Yamalube is showing 10wt and 20wt, but there may be others available. Different models of our bikes use slightly differing amounts.
    Because fork oil is motorcycle-centric, best bet is bike shops and dealerships. The big names in auto parts may carry limited stocks of bike products.
    Yamaha's Yamalube products:
    https://www.yamahagenuineparts.com/Yama ... be&start=3
    Z
  7. samsr
    samsr Member
    Colorado Springs
    I finished rebuilding them. Fairly simple once you make the special tool. I used 15w fork oil. I purchased from the stealership. Thanks for the information on the amount. Helped out a lot.
  8. ridz
    ridz Member
    Hey sam good to hear from you again..Nothing important here, was just going to say I made the "special" tool out of conduit and 2 bolts and then welded a nut on top of the bolt head..works perfect..you want a pic :c-ya l8tr :wink:
  9. schmuckaholic
    California
    Meh. Conduit, one bolt, and a cotter pin.
    I'll show you mine if you show me yours, big fella... :mrgreen:
  10. Old-Grunt
    Old-Grunt Member
    I'll show you mine if you show me yours, big fella... :mrgreen:[/quote]
    8O :oops:
  11. ridz
    ridz Member
    Wow wasnt ready for that one :oops: But hey guess im game..Ifn you dont get mad cuz mine has more girth and is about as rigid as a piece of blue steel 8O :wink:
    P.S I must be bored...Hey ol grunt you watchin that weather be be safe..Ridz 8)
  12. samsr
    samsr Member
    Colorado Springs
    I used a piece of 3/4 rod bent at a 90 degree angle and the welded a 2/4 bolt to it. I believe that the head of the bolt was 7/8 Lots of leverage. Worked great. Took 2 hours to do the first one and about 15 minuts to do the second. Nastiest oil I have seen in a while came out of there.
  13. ridz
    ridz Member
    Hey what did your oil look like? mine was dirty brown and milky clear kinda..wich I can only assume is water..the housing oil was blackish, the slider tubes as I call them where 1 milkish #2 clear kinda...hmmm anywayz im rambling now so..To finish I was just curious..
