Aftermarket Carb Intake boots
Discussion in 'XJ Technical Chat' started by jaiblevins, Sep 1, 2012.
  1. jaiblevins
    jaiblevins New Member
    Garland, TX
  2. Orange-n-Black
    Memphis Area
    I've seen similar boots on JCWhitney.com. What you need to find out is the height or length of the boot so the carb rack will mount up and the measurement between the mounting bolts to the head. Of course these boots don't have vacuum nipples.
  3. jaiblevins
    Garland, TX
    ok, this is probably a really noob question, but what difference do the vacuum nipples make?
  4. maverickbr77
    maverickbr77 Member
    Lowville, New York
    need the vacuum nipples to do a running synch and to operate the petcock.
  5. jaiblevins
    Garland, TX
    OK. So I'm really new to this. What are the drawbacks to not being able to do a running sync, and not being able to operate the petcock?
  6. maverickbr77
    maverickbr77 Member
    Lowville, New York
    running synch balances your carbs and makes it so your cylinders are working together nice and even. petcock is what allows your fuel to run out of your tank and into your carb and then to your motor. you can get a petcock that is not operated by vacuum if necessary.
  7. karl
    karl New Member
    KS
    If your old intake boots are cracked and creating vacuum leaks you definitely should buy new boots. I paid around 200$ for 4 new boots for a XJ750. Probably best to stick with the original factory boots. You also will need to have a carb synch tool to tune the carbs. After I cleaned up my carbs the bike ran like junk until the carbs were synched - after that it ran pretty decently. Carbtune sysnch pro through XJ4ever will cost around $100 but if you plan on synching ur carbs u will need these. Carbtune is a few more dollars than some other gages but they dont use fluid - they use metal rods which should hold up a lot better over the long run.
  8. mlew
    Those boots will not work. They do not have the proper angle to mount the carb rack to the head.
    PM Chacal for a price quote.
  9. adrian1
    adrian1 Active Member
  10. biggs500
    biggs500 Active Member
    Sherwood WI
    +1 with mlew. Just order the correct parts from Len.
  11. jaiblevins
    Garland, TX
    Thanks for all of the info. Will PM Chacal for prices on OEM parts. Just haven't been able to find OEM, which is why I looked at these.
