WTB:ASAP: Ignition coil or wires
Discussion in 'For Sale, Trade/Swap, Wanted' started by jbounds, Sep 3, 2012.
  1. jbounds
    jbounds Member
    Troy, NY
    Hey all I'm not to sure if you can get the wires separate from the coil but my number 1 cylinder isn't firing so I would like to get a new used coil for it. And if you can take the wires off then I will just need the wire then. If you can help.me it would be greatly appreciated. Thanks Justin
  2. wwj750
    wwj750 Member
    central minnesota
    The coil that fires #1 also fires #4 at the same time. The other coil fires #2 & #3. You may want to double-check to see if the coil is the problem.
  3. jbounds
    jbounds Member
    Troy, NY
    I'm not getting any spark on my number one, but number four is still firing. And I beleive its just the wire but I don't know if you can replace just the wire...wherein lies the problem as to if I have to buy a coil or can I get just wires.....
  4. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Try cutting the wire back about a 1/4" and screw the cap back on. Might just get a better connection and save you the trouble of changing the coil.
    If you really want some fire power get a set of Dyna coils. See xj4ever he has them and the brackets to mount them properly.
    MN
  5. maverickbr77
    maverickbr77 Member
    Lowville, New York
    to replace the wire you have to cut into the coil body and do some pretty major surgery. also test the cap itself as they can go bad internally.
  6. jbounds
    jbounds Member
    Troy, NY
    ok i will try that and let you all know if I need anything, thanks a lot
  7. TIMEtoRIDE
    A thing to try is swap plugs - 1 for 2 ; 3 for 4 , as your #1 plug could be fowled.
    New plugs recently solved someone's problem.
  8. permissiontolandfmx
    permissiontolandfmx Member
    Edmonton, Alberta Canada
    If you still need coils I have an extra pair that work.
