xj900f
Discussion in 'XJ Technical Chat' started by carrot, Sep 7, 2012.
  1. carrot
    carrot New Member
    Hi can anyone tell me the plug lead order and which one gos to which plug ? On my xj900f
  2. wizard
    One coil does 1 and 4, the other 2 and 3, sometimes the lead length gives a clue.
  3. carrot
    carrot New Member
    Do you know how to tell which one is 1 and which one is 4?
  4. Ross1
    Ross1 Member
    Syracuse,NY
    Doesn't matter,both leads fire simultaneously . Also,the coils fire twice per crank cycle (wasted spark). But only one spark has fuel to ignite, hence the term.
    You have a 50/50 % chance of getting it right,or wrong. It's pretty simple
    1 & 4, 2 & 3.
    Like Wizard wrote,check the lead length. I can't imagine that all four leads are the same. On coil has shorter leads than the other.
  5. carrot
    carrot New Member
    OK nice one thanks
  6. maverickbr77
    maverickbr77 Member
    Lowville, New York
    1 and 4 are interchangeable as are 2 and 3.
    I was a little slow on the draw that time lol
  7. carrot
    carrot New Member
    Hi thanks for that I also think the camchain tensioner is sticking can I just remove it if so can. You tell me how :)
  8. mlew
    No you can not "just remove it" the engine has to be in the correct position or you risk messing up the cam chain timing. There is a detailed procedure in the service manual, I suggest you get one if you do not have one already.
    Please explain why you think it needs to be removed because it is sticking.
    Valve adjustment is critical , have you checked them?
  9. carrot
    carrot New Member
    Hi. The bike has been standing for about 9 yearS the top end sounds a bit noisy and I was told they do this some times
