You've been warned, be careful
Discussion in 'Hangout Lounge' started by Polock, Sep 14, 2012.
  1. Polock
    this doesn't happen often, but it does happen
  2. broberg
    broberg Member
    Sweden, Östergötland
    a buddy of mine had that happen in his boat recently, he wasn't thrilled I might add, battery "acid" everywhere!
  3. MrPhys
    MrPhys Member
    Knightdale, NC
    what happened here?
  4. Kickaha
    New Zealand
    Battery explosion by the look of it
  5. Polock
    that's a starter battery for a pad mount diesel generator set to test start automatically once a week. it didn't start this week
  6. jeffcoslacker
    jeffcoslacker Member
    SW MO
    They'll do it from internal arcing across plates when they get real low on water, exposed plates and too much empty volume for hydrogen sulfide gas...surprised you don't see it in motorcycles more...
    I actually got to see one go, just happened to be looking the right way at the right time at a gas station...gal got in her Honda Accord, hit the key and BOOM. Actually lifted the corner of the hood a bit when it went. Battery looked about like the one pictured...
  7. MercuryMan
    MercuryMan Active Member
    Springdale, NWA
    Concentrated hydrogen really likes to explode. In most explosions or even burning fuels you are witnessing hydrogen igniting-i.e. gas is a combo of hydrocarbons.
    Obviously this is why you are always told to be careful around batteries. As the explosion would be bad, but being sprayed with conc. sulfuric acid would be worse.
    Polock did the acid eat anything around it?
  8. mtnbikecrazy55
    Whoa. Scary. Especially as my battery "died" when I was out of town and not ridden the xj in over 3 weeks. Jump started with car once to ride to friends house. Pulled battery to put in charger, and noticed there was literally 1/2" of "acid"/water in the bottom of the battery :O
    Added some distilled water till it was at "max" and then charged it overnight/till it was full #autoshutoff
    Haven't checked it since, but has since have ridden frequently.
    This thread makes me want to check it 8O
  9. Orange-n-Black
    Memphis Area
    When I worked at a alternator rebuild shop, my boss was checking out a car. He was standing near the battery and asked the owner to crank the car, BOOM. Sounded like a shotgun blast, blew acid all over the car and my boss including the eyes. That's why it's good to have emergency eye wash stations and a shower stall at work.
