syncing
Discussion in 'XJ Technical Chat' started by Bobbybonez, Sep 16, 2012.
  1. Bobbybonez
    Bobbybonez Member
    Sioux Lookout, ON
    What would cause the synctube hooked upto the first cylinder pop off while syncing. It wont stay on there long enough for me to do anything
  2. Polock
    either the hose is too big or your valves are out of whack
  3. Bobbybonez
    Bobbybonez Member
    Sioux Lookout, ON
    OK well I have to do another bench sync so I was going to double check my valves while I had it apart. Thanks
  4. Bobbybonez
    Bobbybonez Member
    Sioux Lookout, ON
  5. Polock
    unless you really want to, you don't really need to do a bench sync
  6. Bobbybonez
    Bobbybonez Member
    Sioux Lookout, ON
    Well I'm pretty sure they will be closer to synced after a bench sync then they are right now
  7. Polock
    no amount of out of sync is going to blow that hose off.
    i just don't like to take carbs off, i'am lazy
  8. Bobbybonez
    Bobbybonez Member
    Sioux Lookout, ON
    Well because I don't really know what I am doing other than what I read on here I'm going to bench sync again lol.
  9. MrPhys
    MrPhys Member
    Knightdale, NC
    sounds like you have an open intake valve sometime during the compression stroke...
  10. KrS14
    KrS14 Active Member
    St Marys, Ontario
    I had one blow off when i was just quickly turning over the engine and it kicked back (reverse stroke with the intake valve open)
  11. KrS14
    KrS14 Active Member
    St Marys, Ontario
  12. bigfitz52
    Is this happening with your YICS blocked?
    Valves in spec?
  13. Bobbybonez
    Bobbybonez Member
    Sioux Lookout, ON
    No yics on my bike fitz. I have done my clearances twice before and after the first time they were still of. Its pretty simple I don't know how I messed it up but I am planning on checking again today
