Is there a way to wire lights to be tail/brake/signals?
Discussion in 'XJ Modifications' started by newbike91, Sep 17, 2012.
  1. newbike91
    newbike91 Member
    South Haven, MI
    I am still new to the bike thing and completely inexperienced with electrical things, but is there a way to have 2 small taillights that will be both brake lights and turn signals? I like symmetry and am not a fan of the "model a" lights that are sometimes mounted on one side of the bike. Plus I don't want the clutter of seperate brake lights and signals. Does such a way exist?
  2. iwingameover
    iwingameover Active Member
    Yes. You need a dual filament bulb on each side, the wiring to go with it and a trailer light control box.
    I have one if you search for my build thread you'll see it. It combines brake/turn into one bulb and you use the tail light filament for that circuit.
  3. bhartmandesigns
    bhartmandesigns New Member
    Tracy CA
    JP cycles sells a controller unit also. About 70$ though.
  4. iwingameover
  5. newbike91
    newbike91 Member
    South Haven, MI
    Ok sounds simple enough. Thank you for the advice and the link
  6. newbike91
    newbike91 Member
    South Haven, MI
    And what if the lights were leds?
  7. maverickbr77
    maverickbr77 Member
    Lowville, New York
    if you are running led they need to be built as a 2 function light and you will need an electronic flasher to replace the stock mechanical one. then wire them to the trailer unit. or you can try to find some that are already built as 3 function lights.
  8. retread83
    retread83 Member
    Homossasa, FL
    Are amber lenses legal in MI? If not, you will need red lenses for stop lights.PO converted my turn signals to dual filaments. I disconnected running light function,amber not legal.Check out Custom Dynamics,got a neat LED stop/running light from them.
  9. bigfitz52
    I know for sure the taillight/stoplight has to be red. And I'm pretty sure here in Michigan the turn signals have to be separate from the taillight.
    Unless you want to argue with a State Trooper about it. I'm sure you know how well that always works.
  10. newbike91
    newbike91 Member
    South Haven, MI
    Oh they have to be seperate lights? :( that ruins all my plans. So much for cleaning up the back.
  11. newbike91
    newbike91 Member
    South Haven, MI
    I thought I read somewhere that you didn't even need turn signals in MI. You would think then it wouldn't matter if they were the same light.
  12. iwingameover
    I have their tag lights with a red LED out the back. Keep the plate lit.
    I'm not sure about the laws in MI. Never been there. If it were it'd probably be motorcycle specific. My truck and my jeep both flash a red light for turn signals in the rear.
  13. newbike91
    newbike91 Member
    South Haven, MI
    Anyone ever try those light bars at customdynamics.com that do signals and running/brake?
