Gasoline gushing from crankcase
Discussion in 'XJ Technical Chat' started by bharveymc, Sep 23, 2012.
  1. bharveymc
    bharveymc New Member
    It seems I have an interesting problem. When I crank my XJ650 gasoline begins to pour from the crankcase output shaft. I've never encountered something like this and I'm not terribly sure how the gas found its way down into my crankcase in the first place. Any suggestions??
  2. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    You may stuck floats, and possibly a bad petcock.
  3. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    Stuck float!!!! Carbs need to be rebuilt if they already haven't been done!!! Do not run that bike until problem fixed.
  4. Fastguy
    Fastguy New Member
    Just went through this myself. DO NOT run the motor. Gasoline leaked past the needle and seat in the carbs and down into the cylinders, leaking past the rings and into the crankcase. Your oil is now mostly gasoline.
    Put some sort of clamp on the fuel line. Drain all of the oil and get a carb rebuild kit. Once I did mine, I bought an inline shut off valve and I shut the fuel off every time I park the bike just to be safe.
  5. Thrasher
    Thrasher Member
    After you drain the crankcase, run some cheap oil in it. Let it heat up, but don't ride it then drain. Refill with the good stuff and new filter. What ever you DO NOT pull the plugs and crank the motor over unless you want a fire. Don't ask how I know.
  6. ryevans21
    ryevans21 Member
    North Iowa
    But Thrasher now we really want to know "how you know"...
  7. bharveymc
    Thanks for the help. I've installed an on/off valve and changed the "oil". I'm just waiting on that rebuild kit and I should be back on the road.
  8. TIMEtoRIDE
    You found the "Molotov cocktail" feature of the XJ petcock !!
    It takes BOTH a faulty petcock AND at least 1 sticky needle/seat/float to flood the crankcase - - just wanted to add that the glue on the oil filter has been compromised, you can stick a couple magnets to the new filter, and that many people have "rinsed" their engine with no ill effects.
  9. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    why the heck dont these carbs have overflow tubes , i've had several hondas and all of them had overflow pipes routed to under the rear of the engine,
    you can then see in an instant if a float sticks, without it flooding the engine
    stu
  10. jeffcoslacker
    jeffcoslacker Member
    SW MO
    Yeah all my Kaws would piss fuel on the ground underneath if a carb couldn't control the fuel...
    When I first got this one, the PO said it hadn't run in at least four years that he knew of. First rough clean of the carbs just to find out if it actually ran or not, one stuck and I noticed it right away...and realized that meant the petcock was hosed as well...
    But who knows how many times that had happened before I got it...first order of biz after making that stop was to change the oil...I used a pan that should have easily held a gallon...I didn't think the oil was ever gonna stop coming! It filled it right to the top, to where I had to skim some off just to be able to move the pan. Probably a 50/50 ratio of fuel/oil!
    As I posted, I put one of those $5 lawn equipment petcocks in the line until I can get around to working on the petcock...but the carbs no longer have the problem of sticking.
  11. bigfitz52
    Some XJs do, some don't.
    If your carbs are in a proper state, it's not an issue.
