Chicken or The egg??
Discussion in 'Hangout Lounge' started by xjlenordski, Oct 3, 2012.
  1. xjlenordski
    xjlenordski Member
    Dubvegas, Australia
    Hi guys,
    I've just finished the carb rebuild (again...don't ask).
    The question is, after bench sync & reinstall, the engine fired up ok...bit rought though.
    Do I colour tune first, then running sync or vice versa?
    I guess I will have to do both a couple of times, but what is best to do first?
    Cheers,
    Tim.
  2. theadbrewer
    theadbrewer Member
    Roseville MN
    colourtune first then sync and do it again from my experience but I am no wizard.
  3. bigfitz52
    Nope. Set all of your pilot mixtures at 2 1/2 turns out; then fire it up and do the vac sync.
    THEN ColorTune. Which will probably screw up the sync;
    so you go back and touch it up.
  4. xjlenordski
    xjlenordski Member
    Dubvegas, Australia
    Thanks for your input adbrewer, but I think I'll take the advice of Bigfitz (I'm sure you would do the same thing!).
    I had a short ride down the road yesterday arvo & it pulled like a train once the revs came up, so I think I'm not too far out.
    Once the revs are up, it sounds good, but at idle it's a bit rough.
    Do I do the vac sync at about 1000 - 1100 rpm?
    Cheers,
    Tim
  5. theadbrewer
    theadbrewer Member
    Roseville MN
    I would go with fitz as well.
  6. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    Yes, 750 idle Rpm is 1050 +/- 50
    You want to sync, then colortune, at idle rpm
  7. TIMEtoRIDE
    Just want to add - that your FINAL setting is based on plug color and seat-O-th-pants feel, like good acceleration without bogging after waiting for a light.
    These things take TIME - and I'd go with Fitz's advise too !
  8. hbwb
    hbwb Member
    west tn
    Whoa dude, your sig on tire date takes me to some thread about screw size for gas cap.
  9. TIMEtoRIDE
    Fixed it - - but why did the link change anyway ?? 8O
