Top end refresh
Discussion in 'XJ Modifications' started by skylrk62, Nov 6, 2012.
  1. skylrk62
    skylrk62 Active Member
    Illinois
    I'm going to do a top end refresh on my XJ900 engine. Is it possible to change out the cam chain without splitting open the lower case? I hear that there can be considerable chain stretch over time? The pistons have a heap of carbon buildup. Anyone have a quick tips on the process the could make life easier on a refresh? I'm trying to gather a parts list of consumables. Thanks!
  2. Bobe7316
    Bobe7316 Member
    Tasmania Australia
    The first thing that you need to buy is a good manual. This will answer most of your questions.
  3. RickCoMatic
    That's the best advice you can get.
    I recommend that you acquire a Yamaha Factory Workshop Manual.
    The Workshop Manual INCLUDES an Owners Manual in front.
    Every single question you might have concerning servicing the Head will be answered in the Service Manual.
    You'll get a Step-by-step instructions and procedures.
    The section on Cam Removal and Setting the TIMING is comprehensive and guides you through the process of removing and installing the Head in a foolproof manor.
  4. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    I would do a compression check to verify it needs refreshing
  5. skylrk62
    Illinois
    thanks guys!
  6. bigfitz52
    Seriously.
    How many miles on the bike? I wouldn't rip into a motor just based on "I heard that the cam chain can stretch."
    If the motor has less than 40,000 miles on it and makes good compression, it probably just needs a good tune up; valve adjustment, carb cleaning and sync, etc.
  7. skylrk62
    Illinois
    What about the carbon buildup? Is there a way to clean that out chemically or a way without removing the heads?
  8. skylrk62
    Illinois
    I haven't done a compression test yet. The engine has approximately 25,000 mi.
  9. bigfitz52
    It's a puppy. Get a compression test; check the valve clearances and if any were too far out, test again after getting them in spec.
    Unless it's been horribly abused you shouldn't need to tear it down.
  10. skylrk62
    Illinois
    Great, that's a relief! What about the large carbon buildup? It looks bad. Ideas?
  11. non_quotidiun
    non_quotidiun Member
    South Western Australia
    Maybe running rich.
    Use the search function.
