super tight valves? am i retarded?
Discussion in 'XJ Technical Chat' started by dbrianson, Nov 17, 2012.
  1. dbrianson
    dbrianson New Member
    Hi, I have been a "viewer" of this forum for some time, just now registered to ask some questions. This forum has been of great help to me while working on my 1981 maxim xj650. Here is a question that i hope you guys can help with:
    I am trying to spec my valves but it seems i cannot get the feeler gauge between to rocker and valve no matter how i position the rocker. I assume the pointed part of the rocker needs to point directly away from the valve to check clearance, am i right? I have a metric feeler gauge but not one of the gauge will go through, not even the .006, not even close! am i doing something wrong or are these valves damn tight? This bike has 22,000 miles on it and i doubt the valves were ever adjusted. The bike runs now after a good carb cleaning but the idle speed seems to change on its own, it will idle at 1000 for awhile the surge to 1600 or so and back down to 1000 after awhile, it just wont settle.
    If these valves are extremely tight, what shims should it go with, all the valves are not allowing me to insert the feeler gauge.
    Im out of ideas, please insert your knowledge below:
  2. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    The correct term for what you are calling a "Rocker" is camshaft lobe. Yes the lobe has to be 180 deg from the valve shim and bucket. You should be using metric feeler gauges and at .006" you are way to tight.
    MN
  3. ken007
    ken007 Member
    Brisbane, Australia
  4. dbrianson
    Camshaft lobe is what I meant to say. And I have looked at the valve adjust topic on here, it is very informative, but I got stuck at the clearance part.
    So, can valves actually be this tight, if so, now what?
  5. MN-Maxims
    Saint Paul, MN
    You'll have to get a manual and follow the instructions on replacing the shims. Would be best to get some used shims for checking purposes.
    I would get the tool to remove the shims. Some here use a zip tie and stick it in the valve you are working on. I like the tool to do the job but to each his own.
    MN
  6. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    You are on the compression stroke, right?
  7. maximike
    maximike Member
    Portland, OR, USA
    Yeah, here's what you do, since they seem to be super tight. Just pull all the shims(one at a time! You have to have the shims in place when that lobe hits the bucket.) Record the numbers so you know what size they are. Then look at the shim chart and move down two sizes. Then, you should at least be able to get a reading to know what size to put in there. But I never heard of valves that tight, myself. Mine were only one shim out of spec when I did mine, if I recall.
  8. MN-Maxims
    Saint Paul, MN
    Doesn't make any difference as long as the lobe is pointed 180 deg away from the shim and bucket.
    MN
  9. bigfitz52
    Oh, they can be that tight, all right. I would pull them and read and record them. Then swap them out for a couple of sizes down as suggested and use that clearance to work with. You'll probably be able to swap some of them around; see what's in there.
  10. dbrianson
    I'll take out the shims and go a couple sizes down to get a good reading. Thanks.
  11. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    If you don't want to buy an extra set of shims for measuring, could you just get ONE that is two sizes smaller than your smallest shim? So pull an measure them all like what was said above, and order one that is two sizes smaller. With one extra, you can play musical shims and get good readings on all of them, then order only the right sizes. You might even get lucky and be able to switch a few without ordering new ones.
    Take good notes on the positions and measurements. And what ever you do, just incase you missed it above, DO NOT rotate the cam lobe without a shim in place (why you need to have at least one extra).
  12. MN-Maxims
    Saint Paul, MN
    +1 Manbot. Be sure not to rotate cams on buckets without shims you will cause damage to your cams and buckets. Only remove one at a time , make a diagram as to which valve has what size shim and go from there.
  13. MercuryMan
    MercuryMan Active Member
    Springdale, NWA
    If your valves are like mine then one of your shims will be 2, 3, or maybe 4 sizes smaller than your largest one-like 290 is your largest and you have a 270 as well. You could follow the above advice and swap the smaller into the larger ones to get a reading-at least as much as possible until you can't swap anymore. That should get you most of the way there or indicate to you how much smaller you may need to go.
    It is also possible you won't have any number printed when you extract your shims because they've been rubbed off. I had one that was like that. In that case you could measure with some digital calipers to get the 'true' size of the shim and go from there.
    The valve bucket holding tool is a little tricky to use-the key is to have it centered (precisely) and keep it from lifting or moving while you tighten the allen screw-that way it stays just on the bucket and lets the shim pop free, and don't let the tip of tool get coated in oil or it will slip off easier. Also in my case the rubbed off shim was VERY unwilling to pop loose. Based on how easy the other's were I take it as an anomaly but it was a BITC#! So the second time I went in I made some tools to help me go faster and be less stressed.
    Check these out made from a computer chip puller
    +1 to what MN says here is a link for a chart I made to keep track, made it for my 550 but yours is the same.
    https://docs.google.com/file/d/0BxLr6l1 ... 2YjJk/edit
    EDIT: fixed the link above should work now.
  14. MN-Maxims
    Saint Paul, MN
    Just as a side note. There is a shim tool out there that does not work quite right. Someone who knows which one it is should chime in here and refresh our memory as to which tool to avoid buying.
    MN
  15. MercuryMan
    Springdale, NWA
    I just picked mine up from XJ4Ever, but I remember someone saying they had bought one from another online supplier and it was bunk-something about it being made for a slightly different setup or maybe it was poorly engineered-don't remember who it was though.
  16. livingdeadlyxj650
    livingdeadlyxj650 Member
    kimberling city MO.
    From my observation you want the one that dosent have a nipple in it. The nipple is designed to go in the gap in the bucket but this blocks your pry point on the shim. Im going to order the flat one that rests on the bucket flat leaving the notch open. I could b wrong about this. But it seems like common sense to me.
  17. chacal
    Nope.....the nipple (tip) of the shim bucket retaining tool rests on the edge of the bucket, and the notch in the bucket should be rotated 180-degrees (exactly opposite-facing) from where the tip of the tool contacts the bucket..........so for example, tip-of-tool on the bucket at 6-o'clock, notch in bucket should be facing 12-o'clock. The notch is where you use a very thin screwdriver blade (or equivalent) to pry/pop the shim loose from the bucket.
    Look at the last 2 images on this thread posted by BigFitz and you'll see the proper method of usage:
    http://xjbikes.com/Forums/viewtopic/t=29209.html
  18. hogfiddles
    For a spare shim to use so that you can do preliminary measurements, contact me..... I run one of the shim pools, and have a couple shims that are good only for that exact purpose. You can then get your measurements and we can set you up with most, if not all, of the shims you'll need. PM me with the little 'pm' button at the bottom of this reply.
    You can also order all brand new stuff from Len Chacal, our local parts supplier/expert extrordinaire.
    As far as the question of 'can they really be that tight'......they sure can, and I've seen ones that are so tight that the bucket is riding on the cam for the full revolution, leading to low compression reading in one cyl. Once the correct shim was in, everything was good. It's just a hassle at that point, cuz you have to do what you're gonna have to do.....put a smaller and smaller shim in until you CAN get a clearance measurement, and THEN do the math to get the Correct clearance again.
    The notch in the bucket is there so that you can rotate the bucket so that you can get to pop the shim out. Do NOT line up the shim tool with the notch.
    I use the tool, but on the last one that I did, I used the ziptie method and I think I'm probably going to do it that way from now on. Once I got the feel for it, I had the whole bike measured and swapped in about 10 minutes.
    Welcome aboard!
    Dave Fox,
    Registrar- XJ900RK(USA-Delivered) Seca Database
    Operator - Central NY XJ Shim Pool
    Host - Central NY Carb Clinic #6, June 2013 (date tbd)
  19. dbrianson
    You guys are awesome, some very good advice that I probably wouldn't have thought about till I had messed up something. Goes to show how experienced shared can make a job so much easier. You guys should be proud of your forum and the knowledge therein. I'm going to remove the shims one by one, record the number and location then reinstall. I'll post my shim sizes them pm the member above to maybe swap some shims around. I'll be glad to trade my existing shims for others I can use.
  20. hogfiddles
    That's basically how the shim pool works. :)
    Yes, we are proud of our forums and we work hard to keep a high quality thing going here.
    Make sure you do the math once you get clearances that will work, then I'd recommend that if this is the first time you've done a shim/clearance check.....post the numbers here, and we'll either confirm or correct what you need.
    Then we'll check what's available in the pools.
    Make sure that you keep the numbers in the correct colums:
    Exhaust 1 2 3 4
    Intake 1 2 3 4
    Dave Fox
  21. livingdeadlyxj650
    kimberling city MO.
    Sooo okay. The nipple dosent fit in the gap in n the bucket. Its to push directly on the head of the bucket. So what's the difference in the two style of tools? Not to try n
    thread jack.
  22. dbrianson
    Ok, so my valves are not ALL super tight, I was using wrong feeler guage, but here is what I have:
    These are the clearances:
    E1- .076 E2- .203 E3- .127 E4- .102
    I1- tight I2- .076 I3- .076 I4- .076
    Here are the installed shims:
    E1- y285 E2- y280 E3- y275 E4- y280
    I1- y285 I2- y285 I3- y280 I4- 275A
    I used a 12 guage electrical wire as a valve holding tool, it took all of 2 seconds to get it in the open valve, it worked great.
  23. bigfitz52
    Oh, they're tight alright. Leave #2 exhaust alone.
    Exhaust #1 and #4- down two sizes, exhaust #3 one size;
    Intakes will all need to go down one size except for the "mystery" which will probably need to change by two or even three sizes.
    Seven out of eight is not a surprise; they've been neglected.
  24. dbrianson
    Thanks a bunch, I wonder If hogfiddles has those shims to swap me?
  25. hogfiddles
    You will able to swap a number of the existing shims over to other buckets. The only things you actually need to get are two 270 shims, plus whatever you end up needing for the #1 intake.
    I have two NOS 270's, no used 270's. I probably have whatever you end up finding you need for the 1 intake one once you know it.
    PM me and I'll give you the particulars of how the shim pool works.
    In a nutshell, the used shims are a straight-up swap, there is a deposit required that is returned when the swapped-out shims are sent to me, minus the mailing cost.
    As far as the NOS shims, I was fortunate enough to come into a big batch of them earlier this year, so I am passing the fortune onto others in these forums in the form of a real good price. There is a reasonable price for flat-out purchase, and the deposit covers that amount. Then, for each swapped shim that is returned to me, there is a portion of the deposit that is returned, and the final cost of a NOS shim ends up being only about what an aftermarket shim would cost.
    Again, PM me for details, and if you wish to speak in person then pm me and I'll give you my number.
    Dave Fox
  26. dbrianson
    Sent you a pm
  27. hogfiddles
    Haven't receid one....make sure that you click the ' pm' box at the bottom of this reply, then fill in the box with the reply. After that, scroll down a bit more and make sure to hit 'submit'.
    Don't know where it went........ so let's try again :)
    dave F
  28. dbrianson
    I just realized that I have this problem on every damn forum I'm a member of, the pm function never works on my iPhone. I'll send through my pc.
  29. OzRoadbandit
    OzRoadbandit Member
    I'd also be looking a #1 and seeing if it had a lean condition.
    #1 valves on my XJ were uber tight. That cylinder had been running quite lean for some time causing valve recession.
    Like yours, the PO of mine was right up on maintenance .... NOT.
  30. dbrianson
    hogfiddles, i need 3- 270 shims, i cant get the pm to send on my iphone or my pc now, i don't know whats wrong, it says it sent but it didn't.
  31. dbrianson
    Here is the old girl i'm working on:
  32. Daniel Scott Merrill
    Daniel Scott Merrill New Member
    Dallas tx
    I know this is very old but what do you mean by wrong feeler gauge I'm having the same problems measuring my shims with the smallest feeler and may need a different gauge
  33. hogfiddles
    1.What is the thinnest gauge you are using....
    2. Is your gauge metric or SAE
  34. Daniel Scott Merrill
    Dallas tx
    I was using the wrong feeler guage and bought a new 32 feeler set. I was able to measure all the valves and all but one were out of spec. The exhaust valves were way out. I want able to pull the shims out yet but I'll post the measurements I took soon.
  35. Daniel Scott Merrill
    Dallas tx
