Gears
Discussion in 'XJ Technical Chat' started by KPXJ750, Nov 19, 2012.
  1. KPXJ750
    KPXJ750 New Member
    New Zealand
    Hopefully this is in the right place....
    Got my old boy back up and running, fresh oil, fresh fuel and new spark plugs, anyways, when riding the gears are smooth and I have no problems, I'm having an issue putting him in neutral when I'm at a stop. If I turn the ignition off I have no problem putting him in neutral, any ideas??
    TIA
  2. bigfitz52
    Clutch is dragging slightly.
  3. KPXJ750
    KPXJ750 New Member
    New Zealand
    That mean a new clutch then??
  4. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    Likely. Old clutch sitting for years half in oil and half out doesn't age well. However, you can try to adjust the clutch throwout so that it doesn't drag.
    If the clutch slips when you do this, then you definitely need to replace it. Replacing sooner rather than later is prudent because allowing the clutch to slip creates heat and can warp the plain plates.
  5. KPXJ750
    KPXJ750 New Member
    New Zealand
    Thanks Manbot! Read your thread, love the look of the bike now!
  6. KrS14
    KrS14 Active Member
    St Marys, Ontario
    If you mean your shifting to neutral at stop lights/sign. That's a bad habit to get into. If you need to move quickly because of some dumb cager, you're screwed
  7. KPXJ750
    KPXJ750 New Member
    New Zealand
    KrS14: I never go into neutral at the lights, like you say I want to be able to get off my mark if I need too. It's when I get home and go to put it into neutral, it doesn't want too.
    Going to have a look at the clutch cable tonight... had a few other suggestions on a NZ forum that I'm on so hopefully will get it sorted, if not next years winter project.....
    Thanks for the replies!
  8. adrian1
    adrian1 Active Member
    too much cable play at the lever
  9. KPXJ750
    KPXJ750 New Member
    New Zealand
    Thanks Adrian. Haven't had a chance to look at it yet....
