Remove black coating on levers
Discussion in 'XJ Modifications' started by broberg, Nov 21, 2012.
  1. broberg
    broberg Member
    Sweden, Östergötland
    Hi
    Has anyone tried to remove the black plastic/rubber-coating that is on the clutch/brake-levers? I mean without grinding it off.
    Is there some solution that dissolves the plastic but is friendly enough not to damage the aluminum?
  2. bigfitz52
    Acetone? Possibly Aircraft Paint Remover (from the auto parts) the same stuff we use to strip the original clearcoat before polishing the covers.
  3. Corrupt_Reverend
    Corrupt_Reverend Member
    Central California
    Maybe gasket remover?
  4. hogfiddles
    Why not just buy another pair of levers that are the plain aluminum levers? Or get a pair of the chrome ones...... You'll spend more time and money trying to 'bald' them than if you just pick up another pair.
    Dave F
  5. danielcarver47
    danielcarver47 Member
    carolina borders
    plastic bag full of laquer thinner, marinate overnight .guaranteed to strip but not etch the metal, its a laquer coating thats used in the factory
  6. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    I used the aircraft remover I already had. Then after they were stripped and dried I hit them on the buffing wheel. Nice and shiny.
  7. bigfitz52
    Really. To dissolve plastic coating. How long will it take to dissolve THE BAG?
    If the solvent is strong enough to eat the coating it will eat the bag. I'd recommend a metal pan; and I don't think lacquer thinner will do it. I'll try it on a scrap lever and see.
    tskaz has already had success with Aircraft Paint remover; I'd go that route.
  8. retread83
    retread83 Member
    Homossasa, FL
    citrus strip paint remover,that's what I used. Got it at Home Depot.
  9. Sinner650Bobber
    Sinner650Bobber New Member
    If its a rubber coating just use DRY ICE ittl pop right off
  10. k-moe
    I prefer FIRE.....just not so much as to damage or melt the levers....and not in the kitchen over the stove :oops:
    in reality, a chemical stripper is easiest; hardly any effort to let it sit, which is my favorite kind of work.
  11. danielcarver47
    carolina borders
    :roll:
    please ignore this guy, i should have specified ziplock freezer bag, it will not get "eaten", just like the plastic cap on the laquer thinner can doesnt get "eaten"
    if you were to use a metal pan it would evaporate overnight and be a fire hazard
    also be wary of anyone who claims to know everything about everything and hasnt outgrown looney tunes
  12. bigfitz52
    Lacquer thinner bounced right off, BTW. Got 'em nice and clean, did nothing to the covering.
    Paint stripper worked.
    For the record: I ONLY speak from experience. If I haven't actually done it or tried it or used it successfully then I don't offer the advice. That's why, for instance, you won't find me offering advice to Max-X owners having fan or thermostat issues; I have no experience with liquid-cooled XJs. I don't claim to know anything. It all comes from EXPERIENCE or you don't hear it from me.
    More people should live by that philosophy.
  13. mook1al
    mook1al Member
    Talladega, AL
    Dan....I dare you to take a ziplock bag full of thinner and lay it on the tank of your bike overnight.
    Better yet, place a Dixie cup on it and fill it with thinner....
  14. RickB
    RickB Member
    Southern Maryland
    Oh yah, well Dan, while this is clearly a flagrant breach of dare etiquette, I "triple-dog-dare-you"...
  15. bigfitz52
    One more item, for the record:
    Duck Edgar Dumas Aloysius Eoghain Dodgers, known to most as "Duck" Dodgers, is no mere Looney Tune. He is one of our pre-eminent fictional space pioneers, from the ranks of such icons as Bedford and Cavor, Prof. Bernard Quatermass, Buck Rodgers, Flash Gordon, James Kirk, Jean-Luc Picard; the list is long and illustrious.
    This is one of the two actual Mission Patches for the 2003 Mars Exploration Rover missions; the other featured Marvin the Martian.
    Apparently NASA hasn't "outgrown" Looney Tunes either.
    Or maybe they've also learned not to take themselves too seriously.
  16. adrian1
    adrian1 Active Member
    Beeppata Beepbata. That's all folks :lol: :evil:
  17. RickB
    RickB Member
    Southern Maryland
    Have you considered a Wile E. Coyote avatar? Believe you've earned it. :)
