650 dead
Discussion in 'XJ Technical Chat' started by swe-eet, Nov 29, 2012.
  1. swe-eet
    swe-eet Member
    steubenville ohio
    Xj 650 it had a few leak and I got it fixed for the most part I can tell. Now it wont fire at all it back fires and that's all she will do. Black smoke will roll out of left side of bike(if u sit on it) out tail pipe and will back fire like a 12 GA went off. Its still leaks fuel on 1 Carb close to left side. But I just can seem to get it to fie so I can check carbs well running. Any Ideas y bike will BK fire only on that pipe.
    Hre the details I've replacement fuel line fixed petcock kinda clean out side of carbs ck. Boots for leaks of air or fuel charging battery not for 100% full power.
    Didn't pull plugs for gap will tho but haven't tuned or messed with carbs beside losses float bowels
    Also inner stupid? I c where the air filter will b by how u get to it. I think I'm over thinking it but I'm done looking I don't want to tool if its a easy get to.
    Thanks for reply. And thank to y'all thatvhelped b4
  2. skw1972
    skw1972 Member
    Milton Florida
    ok lets back up for second so I can wrap my head around that. If Im reading what I think Im reading I think you are way rich.
    Are the carbs CLEAN?
    Have you VERIFIED fuel levels?
    Does the oil smell like Gas?
  3. swe-eet
    swe-eet Member
    steubenville ohio
    No oils fine carbs yea leaky but cleand an the fluids good rich maybe. It ran good w few days ago then I let it sit well I fixed a few odds. I go to fire it and this is what I got a back fireing 12 ga in my basement. Its a 82 maxim 650 it that will help any more.
  4. skw1972
    skw1972 Member
    Milton Florida
    first thing you gotta do is make sure the process is complete with no short cuts. A short cut is the fastest way right back to the start.
    First off the "leaky" carb sounds like fuel levels wayy to high maybe? causing an over rich condition.....un burned fuel is igniting in the pipes causing the backfire... and or dirty carbs maybe causing a float to hang, bent float pin, etc.....
    start with getting the carbs really clean. use new gaskets and float valve seats and needles. clean and polish the slides and bores with some 1500 wet sand and pb blaster. I boil my carbs but stay away from cheap spray carb cleaner..it eats shaft seals and o rings. use new orings everywhere you have one. then verify the float levels with a clear tube then set the cam chain slack and adjust your valve lash.
    After that do a runnining vac sync and tune. Start with step 1 though.. pull that carb rack and get it CLEAN CLEAN.....dont forget the slide bores
  5. MercuryMan
    MercuryMan Active Member
    Springdale, NWA
    It's not dead just needs treatment. When you throw a rod or it bursts into flames then it may just be dead.
    What skw1972 has told you is good advice especially with respect to not short cutting. These bikes are great when they are properly maintained, but they are performance based machines with fine tolerances so if it ain't right you will have problems.
    If you have dirty carb issues and you start cleaning but don't go all the way it will only make it worse. Those tiny passages will get clogged by what you broke loose or your float valve won't seal up. The 'shotgun' blast backfire is caused by fuel vapor building up beyond your exhaust valve and then igniting. It can be an over-rich condition, but it can also be caused by simply cranking away with the 'choke' enrichment on when the bike won't start. The only way you can know and fix it is to go step by step through the proper maintenance.
  6. OzRoadbandit
    OzRoadbandit Member
    have you unplugged the ignition coils or taken the plug leads off at all ?
    Sounds like timing is out a long way like a plug lead in the wrong spot... just a though
  7. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    I'll jump on the carb band wagon here.
    That leaking #1 carb is because of WAY to high fuel levels.
    The carbs need to be wet set.
    The float is set too high, allowing fuel to come back up through the air jets and flood your bike.
    Open up the seat, take out the 3 screws (or at least there should be three) for the air cleaner cover. It's the piece that the fuse box is attached to. Pull the air filter out and take a whiff, bet it smells of fuel.
    You need to get those carbs cleaned, then wet set the fuel levels, before it will even think of starting for you.
    But this is only one step in many that need to be done before you try starting it. Like the others said, you will need to check the oil for fuel, check and adjust valve clearances, etc.
  8. swe-eet
    swe-eet Member
    steubenville ohio
    Well like I said oils cool but float sound bout right I was thinking it then I just tighten Carb bowels and it dont leak as bad. But is Carb work really as hard as it seems? It sad the bike ran last week but now it just a basement show piece. But I could Ck air box cuz I never could find it. I just got bike 2 weeks ago so please don't say I neglect it I've never rode it to neglect it. But thanks ill pull drain and fix float hope it runs right after but any more Carb help is welcome or link with pic be best. But one more fast? I heard to drain plugs anyone no where it is and dose that mean it got 2 fill holes
  9. bigfitz52
    Granted, YOU haven't had the chance to neglect it. That happened in the 30+ years before you got it.
    YOU get to "undo" all of the neglect. Going at it the way you are will not work. You need to be methodical, and diagnose; not grasp at straws and jump to conclusions.
    EACH carb has its own drain plug; each carb has its own float.
    I'm gonna say it again: GET A BOOK!
  10. swe-eet
    swe-eet Member
    steubenville ohio
    Books on It way its gone a take a few weeks to get. I'm not around a bike shop that could help so I hunted one down. How ever I Diaz it b4 I understand a need the book I under stand I'm redoing a 30 year old bike I get this its a nice bike and its not a rocket science motor to fix. I just want to get a few ideas ofbwhat might be wrong or what might fix it an so on b4 I pulled it apart to fix everything. Thank you for your concern but I'm not going 2 ride a 30 year old bike b4 its all new anyways. I just wanted ideas and tip hints little no how. B4 I got dirty that's y I'm on this site to find out and ask if not found.
    My fault f I'm ticking people off asking? But that's y this site is here I thought
  11. swe-eet
    swe-eet Member
    steubenville ohio
  12. skw1972
    skw1972 Member
    Milton Florida
    might want to pull a compression check too. At least I would if it was mine.
    Not saying low compression is anywhere near the problem but if you are gonna work on it you may want to get an clearer picture of what you are working with.
  13. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    New to you bike has to go through the following to run well.
    1. Valve adjustment
    2. Compression check
    3. Thorough carb rebuild and clean (nothing wrong with canned carb cleaner, dipping the carbs in carb cleaner will eat o-rings, but the short contact and evaporation of canned cleaner won't)
    4. Intial set up of carbs (bench sync, pilot mixture screw setting,float height adjustment).
    5. Running sync and pilot mixture adjustment.
    6. Fluid change
    No one's mad, we just don't want you to keep taking shots in the dark. The above is the best methodical process to get the bike up and running. Leaking floats can be cured with the above method, along with other issues who's symptoms you haven't had a chance to notice yet.
    And no, carb cleaning/rebuilding isn't hard. There are certain pitfalls (and great How-To threads on this site to help you navigate them). It just takes patience and time.
    Beyond running well, you'll also need to restore the braking system, verify the charging system function, grease or replace bearings, replace old tires, and replace any old leaky rubber seals throughout the bike to make it a reliable rider.
    The motor is not going to be an issue unless you blow bad compression. The intake needs to be 100% to get these bikes running reliably, the engine itself is rarely the cause of no-start conditions.
  14. swe-eet
    swe-eet Member
    steubenville ohio
    Thank you never would of b4 I started that. Anything I should ck keep in mind bike wont start either still but I got 2 months to pull it apart and redo odds. Anyways but that would help and here's my plans since I'm on the topic of asking? B4 I do big time work.( like to no what I'm getting in to b4 I start) doing the carbs are a giveing I just want it to run one more time b4 I broke it down cuz I got wires to ck and stuff b4 but I'm stuck and can't now so it have to wait. But new gasket brake and bulbs are getting done and bodywork bikes apart should just do it when it apart. And relube everything. Anything else I should ck 4 I Start my to do list.
  15. swe-eet
    swe-eet Member
    steubenville ohio
    Manbot13 u hit my thoughts and doing on the nose there and yea ur right I'm takeing comments the wrong way so sry but how ever my thoughts and ideas r different thinking then some1 else trial and error is the teaching way of being a king at stuff how ever the info from y'all people r keeping my hands clean for now an giveing me great heads up.
    Bout what about the 2 drain plugs and dos it got 2 fill holes or just that one on right side that's confuseing me a little bit y it got 2 plugs
  16. skw1972
    skw1972 Member
    Milton Florida
    yeah man I wasnt trying to scare you with the compression check, and as I said I never thought you had a low compression issue. I was just saying if you are going to work on it (or anything else) knowing the compression has value on multiple levels.
    But beyond that it was only a suggestion from a personal opinion if you plan on bringing the girl back to good health.
    All that mind you has nothing to do with carb issues. Sorry if I confused you
  17. bigfitz52
    What plugs are you talking about? For the OIL? Or carb drain screws?
    Here's the oil drain plug; it's "underneath" on the front of the sump. The filter housing (the finned thing) also needs to come off to change the filter; you remove its center bolt.
    On the shaft driven bikes, there is also a "Middle Gear" oil drain plug that you probably can't even find. That's good; it doesn't need to be opened anyway.
    Here is a pic that clearly shows (2) of the (4) carb drain screws, although these are Mikuni carbs:
  18. swe-eet
    swe-eet Member
    steubenville ohio
    No I understand the fact of the comp. Test hats just smart thinking..... and I saw on a form on here that some1 said the engine it self has two drain plugs and that's what confuseing me. I don't see two drains on the motor for oil .... I only no of the one in front like the pic shows and filter. ....
  19. swe-eet
    swe-eet Member
    steubenville ohio
    I. Do no of the middle gear plug I've seen it but I'm starting to think from ur post that old form was miss lead hints y it didn't have a lot of reply s And no pic. Or I miss read it
  20. maximike
    maximike Member
    Portland, OR, USA
    The reason we tell people not to remove that middle gear plug is: 1. It's not needed, you can drain the oil as much as you need to from the drain plug on the front. 2. You can very easily break or strip that middle gear plug. Then you have a problem you don't need.
  21. swe-eet
    swe-eet Member
    steubenville ohio
    I get that so What reason for it anyways? Hell tip bike forwards And u should get it dry any ways and life b Easter. But thanks tor the help this sitehelp a lot and ill b redoing my bike soon well it snows out side
  22. k-moe
    Could you please stop texting. M8kes it hrd 2 rd wt U r syng.
  23. swe-eet
    swe-eet Member
    steubenville ohio
    A little. Rude there on the comment thank you for your concerning text how ever I like to no every little bit I can so ... if it bothers you That much don't read what I have to say.......everyone else is able to help and that. gave a lot of useful info even with my text
  24. bigfitz52
    I don't think it was rude at all. It is a bit difficult to "translate" your particular style of keyboarding shortcuts; and it would help anybody that's trying to help give you better information. There's a big difference between "know" and "no."
    Plus it gives us the impression that you're not putting much effort into it.
    Find a service manual yet?
  25. RickCoMatic
    Draining the Middle Gear Cavity is not necessary during a routine Oil Change.
    In fact, it can become a catastrophe if the Drain Plug fractures and causes a leak.
    Repairing a damaged Middle Drain Plug is HIGHLY LABOR INTENSIVE.
    The Exhaust System needs to be removed making rusted and seized fasteners a complicating factor.
    Depending on the Bike, the Engine might need to be unmounted, or the Bike may have to be turned-over upside-down, requiring loads of prep before actually inverting the bike.
  26. swe-eet
    swe-eet Member
    steubenville ohio
    Yea I put the service book on order. Should have it by mid week. I'm not around a Yamaha shop so I went to he Honda shop and they are helping me out. But yes an Mike I told the one Guy on here y'all got me ready to get stated anyways so I got most tear down done.
    I'm just haveing problems with what rebuild kit to the carbs I should buy I found 6 different ones and my bike has pods so I don't no what's best. P.s custom pods its put inside factory air box but the box is gutted hints why I couldnt find air opening cuz its custom done..
  27. RickCoMatic
    That strange Airbox / Intake configuration is highly likely to be upsetting the Fuel Delivery situation some kind of way.
    See if you can acquire an Airbox and Boots off Ebay or from some BoneYard.
    Take a step toward making thing right.
    http://www.drumhillcycle.com/Used_Yamah ... /3,3880199
  28. swe-eet
    swe-eet Member
    steubenville ohio
    I'll try to get u a pic if I can but ill explain how its done. Its a werid to you as is me. It puts me in mind of a off road truck that's n the water a lot .
    The box is that rectangular shaped black thing . But the back that's under the seat has a whole. And the black boots I think ur talking about that hooks Carb to box are still there. However in side the box its got 4 pods hook in them tubes but coverd .
    So yea ur right why they do it no one knows dose it look good not really did it run Good don't know only fired it 3 times.
    What's what's best too do box it. Find a box to use since mines cut or use the pods that I already have.
    If so what jets and what rebuild kit because I found 8 dollar rebuilt kit that is gasket needle vavle and something else I can't remember at this point
  29. MercuryMan
    Springdale, NWA
    Yea that's going to require a picture.
    Be careful buying the kits from just anywhere/anyone, some aren't the right ones or are incomplete. You could go with XJ4Ever (top right of this page link) he has what you need, but if you buy elsewhere just ask enough questions to be sure they are for your carbs.
    Truly it is like building Frankenstein man, so weird s&$t happens when you are trying to animate the unanimated-if you get my drift-they probably had issues tuning and tried a hybrid!?! Yea pics please.
  30. swe-eet
    swe-eet Member
    steubenville ohio
    Trust me as soon I get it apart better to show I will might b a bit but I got 3 months
  31. RickCoMatic
    You should strive to return it to stock configuration to simplify your effort to get it running right.
    After you have the Bike running decently with an airbox and conventional tuning, you are free to experiment with Mods with the option to return to stock if you get frustrated.
    http://www.ebay.com/sch/i.html?_sacat=0 ... ox&_fscr=1
  32. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    I 2d that ^. All other members in favor of Rick's suggestion please motion with the proper sign.
    Gary
  33. MercuryMan
    Springdale, NWA
    Sounds reasonable and intelligent, two thumbs up.
  34. swe-eet
    swe-eet Member
    steubenville ohio
    Lmao yes agrees. Start Carb work found a problem with the 1 Carb and fixed it now it runs took a bit to reprime all carbs but it still lives..... now I'm looking for a rebuild kit yet but I'm working on it....all in all I'm tearing deep in to the bike tonight... ( don't like the inside of number 2 piston) When I removed plug so I'm forced to dig deep rather then Carb redo and yes I got book to start but I'm looking for another beside hyanes
