XJ1100 self-cancelling turn signal
Discussion in 'XJ Technical Chat' started by HalfCentury, Jan 7, 2013.
  1. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    My 1100 turn signals do not self-cancel. Is this a feature missing from the 1100 or is my bike in need of diagnosis?
  2. kjohnson
    kjohnson Member
    Wetaskiwin, AB, Canada
    Your XJ1100 should have it, assuming the gauges and electrical are all stock. IIRC diagnosis would have to be done on both the auto-cancel circuit and the headlight reserve unit.
    edit: one test set:
  3. HalfCentury
    HalfCentury Member
    Virginia Beach, VA
    The gauges appear to be stock but the speedo and tach are both non-functional.
  4. kjohnson
    kjohnson Member
    ah, if the gauges are non-functional, that could be the problem. it may be a simple fix or it could be a never have auto-cancel. when the gauges worked properly on my XJ1100, i found the auto-cancel to be problematic at best and would often blow the signals fuse every time it cancelled. now i have unplugged the module and just manually cancel.
  5. MiCarl
    There is a sensor in the speedometer the self cancel unit uses to measure distance traveled. If the speedometer isn't turning the self cancel unit measures 0 distance and won't cancel the signals.
    Fix your instruments first.
  6. mlew
    Yes , get your gauges to work first. Speedometer is easy there are only 3 main parts, cab;e, drive gear and speedo itself, A non working tach is a good indication the alternator also does not work. The XJ11 tach is driven off the alternator.
  7. Mike82mxm
    Mike82mxm Member
    Ste,Annes,Manitoba,Canada
    Does that include the maxim 750s too
  8. maximike
    maximike Member
    Portland, OR, USA
    Yep, same on 750. The switch itself looks kind of like a fuse. It's mounted on the back of the face of the speedo. If you take the cluster apart, you can hear it opening and closing when you turn the speedo cable by hand. You can eliminate it as the problem by running a jumper wire to bypass the reed switch. Then you turn on the signals, and open and choose the jumped circuit a whole bunch of times, see if it cancels. That is, if you have a functional stock speedo on the bike.
  9. Daniel33
    Daniel33 New Member
    Bordeaux
    you can test it using a magnet
