shorter rear shocks
Discussion in 'XJ Modifications' started by jctxrt, Jan 30, 2013.
  1. jctxrt
    jctxrt Member
    Hi, after some advice on where to get shorter than standard rear shocks for my XJ 650 83 mod. Would like to drop the rear by 2" or so.
    cheers
  2. Henkies
    Henkies Member
    The Netherlands, Europe
    Suzuki Savage shocks is often opted for.
    Honda Rebel fits as well, but is a small 250cc bike.
    Some Sportster shocks are an option, but obviously Harley spare parts are more costly than the Savage...
    Where to get them? I'm from Europe, can't help you on that...
  3. sebwiers
    sebwiers Active Member
    If you do find some shocks that are 2" shorter, be sure to check that your swingarm can freely move up as high as the shorter shocks will allow without binding the U joint, and the wheel doesn't hit anything (like the inside of fender) when it does so.
  4. bigfitz52
    Just order a set of Progressives for your bike in a shorter length.
  5. sebwiers
    BigFitz - do those shorter shocks also have travel that is equally shorter? Seems like if not, you run the risk of blowing money on something that lets the swingarm go higher than it should.
  6. 82NewToMe
    82NewToMe Member
    Harrisonburg, VA USA
    I have HD Sportster Shocks on mine, don't think I weight enough to use all the travel.
