going to look at a XJ750 Maxim
Discussion in 'Hangout Lounge' started by robbiemcvee, Feb 7, 2013.
  1. robbiemcvee
    robbiemcvee Member
    England
    Hello, there is a XJ750 local to me up for sale, this is a maxim import from the US, it is a 1982 it was first registered in the usa when it was imported to this country it was registered 2001.
    Apparently its having a job starting, i dont know the history of it and it appears to only go to 85mph on the speedo
    I wonder if you can give me any tips as to what to look for, why it might be poor starting (other than the carbs need cleaning) and why it may only go up to 85mph - is there a restriction there somewhere?
    cheers all
  2. Krafty
    Krafty Member
    Point Clark ON
    as for the speedo, its just what they put on those years, I believe there are some later models that you can swap for a higher range speedo, there are no limits on the motor. They probably figured if you're going faster than 85 you're probably gonna get a ticket weather you know how fast you are actually going or not.
    How many miles does the bike have on it?
    typically when you buy a bike that old you want to go over all the safety stuff first, brakes tires, controls.
    so most important would be to ask about new brake parts, if the current owner kept up with regular maintenance. ect..
    The xj's all are pretty stout motors that can handle alot of abuse, and miles with the proper maintenance done.
    as for the starting all we can do is speculate from here, but once its running that will tell a bigger story as far as the condition of the carbs.
  3. wizard
    Check the compression, with the valves in spec & the carbs cleaned & tuned, it should start OK,
    Where are you in the UK ?
  4. robbiemcvee
    robbiemcvee Member
    England
    Thanks Krafty - Thats good news about the speed restriction, we can get away with a little more in the UK is suspect. Its done 32,000 miles and has some new tyres. I think its pretty shabby so i should get it for a good price - but this really depends on that starting problem. He says its since its been cold.
    Hopefully he will be able to start it when i go to see the bike
  5. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    Robbie,
    There is a large list of things that should've been done to the bike since 1982. Sometimes things on the list are skipped because they "look good" or don't seem to be an issue. A lot of times people try to fix the symptoms and not the illness.
    Like wizard said, you should test compression on each cylinder and check valve shims clearance. This is just a starting point to find out how the motor is but this is not the only thing.
    Good luck and keep us posted.
  6. robbiemcvee
    robbiemcvee Member
    England
    oh - quite alot to do before i buy it, or should i just take a punt?
  7. robbiemcvee
    robbiemcvee Member
    England
    sorry - im in cambridge, the bike is in peterborough. The chap said he was using it until Jan, still has MOT and TAX
  8. ecologito
    NASCAR Country, NC
    Small world, I have a very good friend who lives in Cambridge.
  9. hogfiddles
    Maybe he's the one selling it... LOL
    REality..........sounds like the carbs need cleaning, and most likely the shims need adjusting.
    Dave F
  10. robbiemcvee
    robbiemcvee Member
    England
    thats what im hoping... yes a small world, it suprising the people we meet..
  11. Kilted_to_the_Max(im)
    Kilted_to_the_Max(im) Member
    Duluth, MN
    I've never had my max over 85, maybe just nosing 90, and that was on a track. Open road, I'd never pass 80, reaction times just aren't there for my comfort...we have lots of animals that sprint across the roads up in MN, or worst the turtles that DON'T move fast.
  12. hogfiddles
    Let me tell you what......when a turtle is after something to eat, they can move pretty darn quick. Or, when it's a big-a$$ snapping turtle that you're trying to pick up with a shovel so you can get it out of your driveway, it's amazing just how quick they can whip around to try and get you. DAMHIKT
    dave F
  13. Kilted_to_the_Max(im)
    Duluth, MN
    The snappers aren't my worry, Dave, it's the paint turtles. Up north and central MN has lots of those little pucks across the roads, day and night. You can get from Duluth to Savannah State Forest just skating on turtles some summers.
    Savannah does have a huge snapper that scares the bajeezus off you while kayaking. I'd hate to be her dinner.
  14. bigfitz52
    For the record, the 85mph speedometer was something that was Federally mandated here in the States during our first big "fuel crisis" in the late '70s, and they appeared on bikes here from around 1979 ~ '80 thru about '83. It was part of the same "effort" that gave us the national 55mph speed limit (which is also long gone.)
    The guts can be swapped for a more realistic clock.
  15. robbiemcvee
    robbiemcvee Member
    England
    Luckily we have no snappers here only the odd woman from the bad side of town...
    I'm waiting on some pictures from the chap today, so hopefully it'll be mine after the weekend - misses permitting .. errk!
  16. robbiemcvee
    robbiemcvee Member
    England
    Well picked it up today, needs a lot of love, id like to replace the handlebars but these have a strange mounting, needs a new gas cap, seat cover amnd it seems like it has a oil leak around the bottom of the block, can ylou help with how to do these
    Thanks all
  17. robbiemcvee
    robbiemcvee Member
    England
    Thanks all
  18. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    To change from the square style handle bars to round ones , you will need to replace the upper triple tree from a 1983 model. At least that's the only way I know how to do it easy.
    MN
  19. MiGhost
    MiGhost Well-Known Member
    It is not necessary to go that far. To replace the handle bars with the round bar style it is only necessary to replace the mounting stubs with normal risers.
    Ghost
  20. robbiemcvee
    robbiemcvee Member
    England
    Ah yes i did find a post about this, very handy ;-)
    looks like that oil leak isn't as bad as i thought, had a good stab at cleaning the old bike up today and its coming on nice, tanks stripped and off for spraying..
  21. robbiemcvee
    robbiemcvee Member
    England
    Here are some pictures when it was with the previous owner
    It looks better in these pictures than it actually is...
  22. quebecois59
    Have the previous owner ever noticed that two engine mount bolts on left side are missing?
  23. robbiemcvee
    robbiemcvee Member
    England
    i doubt it.. lots more like that on the bike..
  24. mtnbikecrazy55
    jeepers. better go over it with a fine comb!! who just unbolts their engine and just leaves it?!
  25. mtnbikecrazy55
    I have a hookup for a seatcover, ill post his info next time im on a computer! :)
    Welcome!
  26. robbiemcvee
    robbiemcvee Member
    England
    Thanks mate - be good to find a seat cover that will fit!
  27. robbiemcvee
    robbiemcvee Member
    England
    well I managed to turn this one around, excluding the seat - wasn't able to find one...
  28. luvmy40
    luvmy40 Member
    Y-Town, OH
    Looks great!
    Look at Saddlemen.com for replacement kits(foam and cover) or seat covers.
    Y671 is their replacement cover for the '82 Maxim 750.
    I put one of their double bucket touring saddles on my Suzuki GS850L and it was good fit for the seat pan but did not have a grommet for the seat lock which comes out of the rear of the seat pan. I had a local upholstery shop install the grommet and finish the seat for me.
  29. ryevans21
    ryevans21 Member
    North Iowa
    Nice! I have the same bike (mostly) and have a couple questions for ya:
    -Where did you get the new handlebars and how did you end up mounting them?
    -Does your master cylinder leak? Its angled downward significantly with your new handlebars; I am sure mine would leak like that.
  30. Kilted_to_the_Max(im)
    Duluth, MN
    Nice job, Robbie. How's it run?
