1982 XJ750
Discussion in 'Hangout Lounge' started by cob1990, Feb 15, 2013.
  1. cob1990
    cob1990 New Member
    Got this bike in January. Got a reckless the day after! Loving it so far, just want to make it a little less square.
  2. Krafty
    Krafty Member
    Point Clark ON
    you really ought to read up on some of the posts that stress Inspecting ALL the major components of the bike before doing anything with it... it could save your life
  3. hogfiddles
    Do you mean you got reckless the day after buying it
    or
    do you mean you got into a wreck less than a day after buying it
    There are several issues you NEED to address before riding, as Krafty said.
    (Brakes, tires, etc.....)
    Dave F
  4. gunnabuild1
    gunnabuild1 Member
    I suspect he got a ticket for reckless driving or loss of licence for same.
  5. cob1990
    cob1990 New Member
    Reckless driving, not wrecked that would have sucked.. Only major issue I have seen so far was a leaky valve gasket which I changed last night. previous owner put new spark plugs, bled front brake, tires are good. I know it needs oil changed.. open to suggestions on other things that I should look into though.
  6. osprey1000
    osprey1000 Member
    Annapolis, MD
    As most on here will tell you, check the brakes. Bleeding the system is usually not enough. On the brake lines themselves will be a Date stamp of when the lines where manufactured/dot certified. Should look something like DOT 10/80 where 10/80 is the month and year they were made. The front lines were only designed to last 4 years. After that, your on borrowed time. If they are as old as the bike they should be replaced for your own safety. Check the seals on the master cyl. and calipers as well. You may not be able to see all the damage to them. So most on here as well as myself would recommend just get the rebuild kit and rebuild them. It is not that hard to do.
    Check your Rear Brake. The original rear brake has a tendancy to delaminate over time and you may have a brake back there that could fail at any time. Better to just replace them, not sure how many miles are on the bike but the rear brake might be due for replacement anyway.
    See this:
    http://xjbikes.com/Forums/viewtopic/t=1 ... art=0.html
    Also Check your tires for date codes on them.
    Besides that just catching up on maintenance with the carbs and checking your valve clearances and you should have yourself a good bike.
  7. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    Did you also change out the rubber "donuts" on the valve cover bolts? They compress over time and don't hold the cover to the gasket tight enough, so even a new gasket might leak.
    I just did a set on my 550 and they were like 1/3 the thickness of the new ones.
  8. cob1990
    cob1990 New Member
    I just did a set on my 550 and they were like 1/3 the thickness of the new ones.[/quote]
    Where did you order those from? I think that may be the problem, gasket still seems to be leaking a little bit.
  9. JPaganel
    Minneapolis
    Len, AKA Chacal.
    This thread is his catalog, but it hasn't been updated in ages. PM him and he will quote you a current price.
    Very likely. It's a very common cause of leaks.
  10. KrS14
    KrS14 Active Member
    St Marys, Ontario
    There's something that you should be proud of....
    Slow down maybe?...
