Interchangeability of Cylinder Heads
Discussion in 'XJ Technical Chat' started by drdee.1, Feb 17, 2013.
  1. drdee.1
    drdee.1 Member
    Banbury. England
    Anyone know if I can fit Xj650 mid 80's Cylinder head on my 85/6 xj700....I know this will offend the purists, but, needs must as the devil drives
  2. day7a1
    day7a1 Member
    San Diego, CA
    Cylinder head???? Valve cover yes, the cylinder head is a totally different size.
    At first I was tempted to just say no, that's absurd. But after looking at the parts fiche it does look like that it MAY bolt up....but then the question remains regarding the gasket size (probably wouldn't match up and seal), compression ratio (you may blow up your cylinder with a too small combustion chamber, 50 cc is an almost 8% difference in size), cam timing (which camshafts are you going to use?), and a whole host of reservations about what could go wrong!
    In short....can you fit one, probably yes. Would it actually run....wouldn't count on it, mostly due to gasket size.
  3. quebecois59
    Here are the cylinder head parts numbers according to the diagrams:
    mid '80's Maxim 650: 5G2-11101-00
    85-86 Maxim 700: 41Y-11101-01
    Now the head gasket part numbers:
    5N8-11181-00
    1FG-11181-00
    Central digits are always the same, is that enough to say if it will fit or not, I don't know...
  4. MiGhost
    MiGhost Well-Known Member
    Just to be clear. The 50cc difference is in the dispacement of the engine, and has nothing to do with the combustion chamber sizing. The 700 engine is actually a destroked 750 using a shorter crank stroke with longer rods. To meet the import restrictions of the time.
    Taking a step backwards, and checking the base gasket shows that the 650/700/750 all share a common base gasket. This would show that mounting studs through the cylinder are the same. Allowing the 650/750 cylinder head to be mounted to the 700.
    On the cubustion chamber sizing. The 82-83 650/750 engines share the same cylinder head. This allows the combustion chamber sizing to be correct for the 700 also.
    The big difference is going to be the intake camshaft. The 750 camshaft has .050 higher lift than the 650 camshaft. This will only make a difference if you are looking for higher top end power. For normal operation. It should barely be a noticable difference.
    Would a 650 head work on the 700?
    I would have no problems with using the combination with the noted difference in cams. There should be little if any noticeable difference in operation.
    The gaskets actually work out to be the same parts under different part numbers. Possibly due to a change in materials, better manufacturing processes, etc...
    One major item that needs to be an absolute must. The 700 was a YICS engine. This limits the 650/750 cylinder head to the 82-83 models that were also YICS engines. The 80-81 650 engines were NON-YICS, and will not work on a YICS engine.
    Ghost
  5. day7a1
    day7a1 Member
    San Diego, CA
    Doesn't the 750 have a 65 mm bore and the 650 have a 63 mm bore?
    I don't see how those gaskets could be the same. I also don't see how removing 2 mm from the diameter of the cylinder, which the combustion chamber matches up to, would not decrease the diameter of both and therefore reduce combustion chamber volume proportionally.
    Of course, if the 650 and 750 have the exact same bore size, then I agree.
    If you do swap it, you can leave the camshafts with the correct bike....
  6. RickCoMatic
    You might be able to get a definitive answer by calling Customer Service.
    Yamaha Motors USA
    California
    (800) 656-7695
  7. day7a1
    day7a1 Member
    San Diego, CA
    I think the better question is....WHY do you ask? Maybe there is a better solution. Maybe there is no problem. Maybe there's pride and a beer on the line....what's really at stake here?
  8. drdee.1
    drdee.1 Member
    Banbury. England
    We have discovered after rebuild of our xj700 and some short distance running that the a previous owner had helicoiled a spark plug hole.
    Fine not a problem...cept the idiot had helicoiled on top of a helicoil....after we had a run a short distance the plug blew out complete with helicoils...thus leaving a hole thats too big to helicoil.
    In order not too lose what is an excellent head we have comissioned an insert with 14mm metric thread and an external diameter of 18mm but turned with a wierd AF type non metric threading......We will then have to tap a thread for the outer threading andscrew in the insert
    Xj650 head is a back up in case the operation falls on it's bum
  9. day7a1
    day7a1 Member
    San Diego, CA
    Oh....I guess pretty soon you may be able to answer your own question. I was thinking you were going to buy one. Have you visually compared the two?
  10. drdee.1
    drdee.1 Member
    Banbury. England
    We are going to have to buy one......should have said that it's a back up plan.
    Thanks for the info everyone
  11. RickCoMatic
    You might be able to save that Head by using an OVERSIZED "Insert" from the
    "TIME-SERT" Brand of Spark Plug Repair --> Sleeves <--
    Similar to HeliCoil, the Time-Sert Sleeve is like a Bushing with BOTH the O.D. and I.D. threaded.
    Time-Sert offers an Option called: "Big-Sert"
    Its an Oversized Insert with Standard Plug I.D.
    Here's a Link to their site:
    http://www.timesert.com/html/bigsert_sparkplug.html
  12. drdee.1
    drdee.1 Member
    Banbury. England
    Thanks for that Ric...we have an agent for them in the UK.
    We got all excited ....then discovered their fitting kit....not the big serts but just the fitting kit is....wait for it.....£300......
    OUCH or what
  13. drdee.1
    drdee.1 Member
    Banbury. England
    Thanks to MiGhost for the ins and outs, do's and don'ts. The post is extremely imformative....
    I'm putting my xj for dummies head on now....
    Why does it matter if we fitted a non yics head onto a yics engine.....sure the yics would not function because the appropriate connecting chambers wouldn't be there.....but it wouldn't stop the engine from functiong, surely
  14. murray
    murray Member
    Sydney Australia
    Any specialist head service / rebuilder should be able to do the job with a time insert, Ive had it done on a xj650 head and a xj900 head, and it was only $ 25 each time Its not a big deal for the specialists,
    Cheers Murray
  15. RickCoMatic
  16. bigfitz52
    All sorts of stuff won't line up correctly; I don't think it would actually "fit" even if the bolt holes line up.
    The "connecting chamber" is on the cylinder casting, it would still be there and possibly get in the way.
  17. hogfiddles
    It MAY be possible to put a YICS head on a non-YICS engine if you also swap the jug/cyls.............. not sure, just seems it back in the foggy recesses of the brain, though.
    Dave F
  18. drdee.1
    drdee.1 Member
    Banbury. England
    The latest
    After talking this over the light suddenly came on....
    We didn't take the head off due to the £70 plus cost of the head gasket....
    Now we know an xj 650 head gasket fits and we can buy it for £20...the head is coming off... spark plug holes welded and retapped as required and the head back on.. annual MOT test and back on the road
    Thanks everyone....I'll put piccies on when it's finished
  19. drdee.1
    drdee.1 Member
    Banbury. England
    :D I was absolutely sure that I had posted the final part,(we hope),of our cunning plan to get this animal up and running......obviously not.
    We did not remove the head at any stage of rebuild due to the fact that head gaskets are an arm and a leg.....£70 plus taxes... $120
    However now that we know that the xj650 gasket is a good substitute.....£20 inc taxes....$30
    The head is coming off.....weld the offending plug hole and retap...
    Head back on....sorted
    Thanks for the help will post piccies
  20. drdee.1
    drdee.1 Member
    Banbury. England
    Something strange going on ....I had posted but it wasn't there now it is
  21. drdee.1
    drdee.1 Member
    Banbury. England
    :( The saga continues.
    We discovered that our local postman has an xj700....
    We also discovered that he had changed the head gasket some 3 years ago....he fitted an xj650 head gasket and has been delivering the mail without incident ever since.
    XJ650 head gasket £26.00....xj700 in excess of £75
    That was it then off with the head. Good job we did this and not just tapped for the inserts from outside. If we had tapped we'd have been right through the edges of the valve seats.
    Heads off.....away to have plug holes welded and retapped...puka
    All we have to do now is source the O rings that sit underneath the head gasket....isn't life fun
  22. 750E-II_29Rbloke
    South Cheshire, UK
    Are you sure when you looked up the 700 head gasket you weren't looking at XJ700X items? That's a watercooled motor and the gasket costs a hell of a lot more than the air cooled ones...
    Anyway, no matter as you're sorted with that, you can get "selection boxes" of O-rings various places that should have something the right size included and they only cost a few quid. Aldi had them a while back! ;)
  23. drdee.1
    drdee.1 Member
    Banbury. England
    No, definitely xj700 aircooled bought in europe and not from the states with taxes....£76
    But the xj 650 is same so saved a bundle....mates a plumber so O rings sourced....
    Thanks for your help
  24. 750E-II_29Rbloke
    South Cheshire, UK
    Wow that's heavy, bet there's a few 700's running about with 650 H/G's at that price! 8O
    Glad you're sorted , she running again now?
  25. drdee.1
    drdee.1 Member
    Banbury. England
    Just stripped it to get the head for ter go to welders on Monday........
    Did forks, seals and oil.......Friday
    Now it's down to Stefan at Weldspray to weld and retap...
    Wilst thats going on we might get the chance to do a bit of rewiring, well a lot really.......onward and upward TCO
  26. drdee.1
    drdee.1 Member
    Banbury. England
    THis is nuts.........We've pulled the head....double/triple checked that the xj650 gasket we bought is EXACTLY the same.
    Had the one spark plug hole welded and then retapped.
    Head back on, cams in and retimed correctly....
    It won't fire....double, triple, quadruple checked the timing etc of everything.....spot on......nothing, nowt beggar all......We have sparks, we have fuel....
    Whats going on here......Has any body any ideas please
  27. 750E-II_29Rbloke
    South Cheshire, UK
    Compression check out OK?
    Not got inlet/exhaust cams swapped or anything? Dunno if its possible, but a comp test will tell a lot :)
    *pinch punch first o' the month!*
