carbon deposits
Discussion in 'Hangout Lounge' started by ahrma69t, Mar 27, 2013.
  1. ahrma69t
    ahrma69t Member
    Manchester, PA
    Does anyone use any type of solvent to remove the carbon deposits from the valves and exhaust ports. I have been scouring the stuff off with scotch brite pads.
  2. Foolber
    Foolber Member
    In an Igloo, on Jupiter¿
    let them soak in a jug of something on the likes of this stuff. its not carb and choke cleaner, its thicker and has different chemicals in it that eat away just about anything. you can get this stuff at walmart, or local auto parts stores, might not be the GUNK brand, but same stuff either way. comes in a paint gallon jug.
    https://www.google.com/shopping/product ... CFUQ8wIwAA
  3. aSECAwrencher
    aSECAwrencher Member
    Space Coast Florida, USA
    Careful with those pads. You might need to polish the valve seats after that. Does anyone know if there's a good thread on polishing valve seats and seals in this forum? I've done a few before and it definately helped compression when those numbers start to get a little funky...
  4. ahrma69t
    ahrma69t Member
    Manchester, PA
    Thanks, I will look for that stuff. I don't want to do any damage scrubbing.
  5. 750E-II_29Rbloke
    South Cheshire, UK
    I've always used light oil (WD40 style stuff) to soak the carbon, and a suede brush (fine, brass haired wire brush) to work it in & loosen the really tough bits before blasting it away with brake cleaner & a toothbrush ;)
  6. Foolber
    Foolber Member
    yea with that carb stuff you usually have to pull it out once every 24 hours or so if its real thick and pick some off, brass works great or if oyu really are worried about doing damage use a nylon brissled brush.
  7. aSECAwrencher
  8. RickCoMatic
    If you have a Facility nearby that does "Media Blasting", ... you can have everything :: Walnut Shell :: Blasted.
    The process will remove all traces or Carbon Deposits without doing any harm to the Head.
    Some places even use high-pressure Steam.
  9. bigfitz52
    I like soda myself.
  10. murray
    murray Member
    Sydney Australia
    + 1 on the soda, have used it on several heads and barrels. Will not damage the metal,or clog the oil passages. Just need to wash the residue off with hot water.
    Cheers , Murray
  11. Special_edy
    Special_edy Member
    Arlington, Texas
    carb cleaner will eat gunk like magic, if you havent tried it already I suggest you get a can and try it on the valve
  12. ahrma69t
    ahrma69t Member
    Manchester, PA
    I can always count on a load of great feedback from this site, thanks!
