This is neat! No more sun glasses!
Discussion in 'Hangout Lounge' started by ryancdossey, May 4, 2013.
  1. ryancdossey
    ryancdossey Member
    Indianapolis, IN
  2. burger
    burger Member
    MN
    Looks expensive. I was going to buy a transitioning shield for my helmet but bell discontinued it and anyone who still had stock raised their prices. It would be nice not to have to switch shields
  3. k-moe
    Go to any auto-parts store. Get a small roll of vinyl window tint. Cut a 1 1/2 to 2" strip as long as your faceshield is wide. Place it along the top edge of the shield.
    Alternatively......become myopic and get Transitions lenses.
  4. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    I like it not always being tinted.
  5. k-moe
    That's why I have just a strip of tint along the top of the shield. As the sun gets lower in the sky I just tilt my head down a bit, otherwise I'm looking through a clear shield.
  6. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    I've got an HJC Helmet with a "One-touch Integrated SunShield" which you basically lower and raise with a switch and button on the top of the helmet. It's really great when I commute with lots of buildings around, as you can have the sun in your eyes for a stretch, then it hides behind the building and everything is too dark. I just flip the shade up and down as I need it, one handed, while navigating traffic in DC.
    The shade is a little cheap and the helmets isn't necessarily the best, but I really like the feature. It might seem a little gimmicky, but I use it a lot. The only real complaint is that the sun shield isn't treated with the same anti-fog coating as the main shield, and WILL fog up on a cold day.
    http://hjchelmets.com/v2kx2/prds_is16.htm
    Cost as much as that LCD when it's on-sale 8) . Of course you can add the LCD on a higher quality helmet.
  7. GrooveJunkie
    GrooveJunkie Member
    Linden, MI, USA
    The internal sun shade on my Scorpion has become a favorite feature as well.
  8. midnightmoose
    midnightmoose Member
    York, PA
    I have two shields for my helmet, a clear and tinted. However, I rarely use the tinted one. I work 3rd shift so it's dark on the way and light going home. I usually just wear shades when its sunny. Next helmet I get will have the flip down shade...will also be a modular.
  9. jpacman
    jpacman Member
    East Central Vermont
    I've used this product in several helmets and it works really well:
    "The Original Helmet Sunblocker" www.helmetsunblocker.com
    It's about $16 delivered and works on the same principal as the cut to fit window shading idea that k-moe mentioned above. You can leave it installed on a non-tinted shield and it won't interfere with your vision or line of sight.
  10. Spiderman
    Spiderman New Member
    Kansas City
    I have Paul jr shades you can buy from Walmart. The lenses are interchangeable. The shades come with a tinted set a red tint set and a clear set. 20$ I believe.
  11. quebecois59
    DO you put it inside or outside your shield? It would be easier outside but would wear a lot faster, but maybe I wouldn't care if it is real cheap!
  12. iwingameover
    iwingameover Active Member
    They don't work behind a shield as they need UV light.
  13. k-moe
    Mine work behind a shield just fine. 8)
    Most face shields only block UV A, some block UV B
    Transitions lenses will darken when exposed to any wavelength of UV light (either A, B, or C)
    Of course there is always going to be some variability.
  14. k-moe
    I put it on the outside of the shield. When I first started using the vinyl tint (about '92) I put it on the inside, but it was more difficult to fit (had to trim it so the shield gasket would seal properly. The current strip I'm using has been on for about 10k miles and doesn't need changing yet.
  15. iwingameover
    Lucky you. I got a pair a couple years ago and they would not change under my helmet or with the windows up in the cage.
    Now I've got a helmet with a flip down sun shield.
  16. pappahomer
    pappahomer New Member
    mi
    or you could do what I do,,wear sunglasses under your helmet. don't get in the way...10 bucks at walmart
  17. motors-guitars
    motors-guitars Member
    Noblesville, IN
    cause its so hard to put on and take off sunglasses
  18. Kilted_to_the_Max(im)
    Kilted_to_the_Max(im) Member
    Duluth, MN
  19. BluesBass
    BluesBass Member
    Clementon, New Jersey
    That is pretty cool but a bit pricey for my taste. I spent about that much on my helmet and it came with an integrated inner smoked visor. All I have to do is push a lever on the top of my helmet and it lowers the tinted portion. A button releases it for the clear-only visor.
  20. Kilted_to_the_Max(im)
    Duluth, MN
    John, which helmet do you have?
  21. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    Thats what i thought pretty cool. Didnt mean to get so much heat hahahaha.
    I emailed them and MSRP is $150.00 it should sell for less.
  22. BluesBass
    BluesBass Member
    I have an HJC IS-16.
    I picked it up at my dealership. They offer a few different inner visors IIRC, two smoked, an amber one and I think there may have been a fourth one as well. The outer shield is compatible with the CL-16 helmets by HJC (my old helmet) and is also available in smoked or clear.
    The helmet is great - the inner liner is completely removable for washing and treated with an anti-bacterial treatment.
    It comes standard with the breath deflector which works great when you are moving but in humid or very cold weather standing still it does a terrific job of fogging up the interior visor when it is down. Once you get moving it clears up quick.
    There is a ton of ventilation too, and a lower insert that blocks off cold air from getting at your chin in winter months (I use it year-round). I was able to mount my Sena SMH10 headset to it easily, though it does not come specifically designed for headset integration. IE: the speakers are just velcroed in by my ears to the liner fabric.
  23. Kilted_to_the_Max(im)
    Duluth, MN
    Nice. I did look at that one but the HJC don't fit my head real well. SparX does, so I guess I get away a bit cheaper. I like that it fits the headset tho, and will try it again if I decide to get one. I know my current helmet won't, but it's hard for me to justify buying a new one until the 5 year (or one fall) timeframe hits.
  24. iwingameover
    I got this one http://www.vegahelmet.com/summit3.0.html Because I wear a size 8 hat and it's the only one that fit. Can't complain about the helmet. The visor works as it should. Good fit and lower noise than my last helmet. The price was a bit high at $250 if I remember right.
