carb second level of H*ll
Discussion in 'XJ Technical Chat' started by scrubby, Apr 17, 2013.
  1. adrian1
    adrian1 Active Member
    Rick - I'm reaching for the dictionary again! :)
  2. scrubby
    scrubby Member
    bevent Wi
    What will a color tune plug do? Not sure to there use I always used an air fuel meter to tune with ( autos) have a set up for tuning bikes with this now so I can get real time air fuel on it. The screws you are referring to are air screws by choke? They are adjusting only at idle? The low to mid air fuel is set by the needle correct? Top end and high mid is off the jet size witch is stock here only mod to bike is a uni filter
  3. scrubby
    scrubby Member
    bevent Wi
    Well another dead end going to look for new Carb and coil maby that will work
  4. scrubby
    scrubby Member
    bevent Wi
    120 psi cold dry check all across one number 3 is at 119 lol good spark across also idlse good valves all at spec got to be the #1 Carb is messed up any clues idles good but fouls under load steady throttle
  5. scrubby
    scrubby Member
    bevent Wi
    Took Carb #1 apart top half cleaner run threw all air jet ports blew it out put back together same thing run it for five minutes fouls out #1 plug. The needle seems to stick when pushed up on the Carb tearing another apart to see if changing from one Carb to another will change this or are these not interchange with one to another?
  6. scrubby
    scrubby Member
    bevent Wi
    One and two cylinder are at different hightails on the needle in the plunger swapping them now hope this works
  7. scrubby
    scrubby Member
    bevent Wi
    Found my problem or so I think one of the needles are longer than the rest can not find a mention of adjustment on these. Is the long one wrong for the carb or are they adjustibule ? What is the hight to set at? and how ?
  8. scrubby
    scrubby Member
    bevent Wi
    HITACHI VACUUM DIAPHRAM AND PISTON ASSEMBLY:
    fs5) OEM Hitachi HSC32 series carbs VACUUM DIAPHRAM AND PISTON ASSEMBLY, the slide piston with the non-detachable rubber vacuum diaphram seal. Although it is possible to repair TINY pin-holes that occur in original diaphrams, anything greater than that will require replacement, as these diaphram are under a lot of pressure and stress and the continued flexing of the rubber will eventually lead to failure. Fits all XJ650 (except Turbo) models, and all XJ750 models.
    HCP69 OEM Hitachi carb VACUUM DIAPHRAM AND PISTON ASSEMBLY, brand new, each:
    $ 244.95
    HCP69SET4 OEM Hitachi carb VACUUM DIAPHRAM AND PISTON ASSEMBLIES, set of 4:
    $ 929.95
    Sombody please tell me that the needle at the end of this thing is adjustabule...
  9. maverickbr77
    maverickbr77 Member
    Lowville, New York
    not really but they are removable there is a plastic hex head inside the piston that needs to be turned a little to release it. there is a spring so be careful things don't go flying. there should be a number cast into the plastic end of the needle to let you know what you have and need.
