bogging out again,
Discussion in 'XJ Technical Chat' started by davec, Aug 20, 2013.
  1. davec
    davec Member
    ontario canada
    idles great cold.. choke,, then choke comes off on its own,, then i close choke,, couple wristies she purrs choke off, after ridin for about 5-6 kmh she starts with that bogging again, not nearlly as bad as before mind you,, im thinkin 1/4 turn in on air fuel screws cause shes an old gurl? could it be coils?
  2. bikeboy929
    bikeboy929 Member
    mahtomedi, mn
    if it is having trouble as it warms up, it could be a vacuum leak, you could try testing for that.
  3. bigfitz52
    1/4 turn IN = leaner?
    Maybe 1/4 turn OUT, why do you think it's running rich?
    Valves in spec, float levels wet-set, carbs vacuum sync'ed? All required prior to mixture tweaking.
