BOGS/RUNS BAD/DIES help?
Discussion in 'XJ Technical Chat' started by j12racer, Aug 23, 2013.
  1. j12racer
    j12racer Member
    fort worth, texas
    this is my second thread. I thought if i made on in the technical discussion area it would get more traffic. Any ways here we go. Bike : 82 XJ750J pods and open exhuast. ran good a few months ago before tear down. I even tried to start it up every couple days to keep the gas flowing somehwhat. Carbs are CLEAN and jetted correctly. It ran fine before for the most part.. Now to start it i have to hold the start button down for 10-15 seconds and it will finally start, but it runs like crap and sounds like crap. If i hit the throttle it bogs down. If i feather the throttle carefully i can get it to rev up nicely. After i have it revving nicely (doesnt last long) i try to put it in 1st gear and give it ago. as i let the clutch out it just bogs and dies everytime. Its like im trying to take off from a stop in 4th gear or something. Is this a clutch, fuel, bad gas, valve adjustment, or roll it down a hill kind of problem.
    Someone please help THANKS
  2. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    Bad gas is an easy check
    Running on all cylinders when it "runs like crap?"
    Coil check is pretty cheap assurance too
  3. mlew
    When it ran good a few months ago did the bike have stock exhaust and air box? Can we assume the purpose of the tear down was to modify the exhaust and intake.
    Have you done the basics? Wet set floats , carb sync and valve adjustment.
  4. MercuryMan
    MercuryMan Active Member
    Springdale, NWA
    First clue is starting poorly. With a fully charged battery, except in the dead of cold winter, an XJ even only in decent tune with good fuel will ALWAYS start better with a quick blip of the starter motor, more than 4 revolutions and you've already begun to suck out the battery's ability to properly fire the coils. This is just how they work. In fact there should be a sticky or tech article entitled "Your XJ likes to start right away, if you keep cranking it's going to keep croaking!"
    Our instinct (mostly derived from Honda's, Mopeds, Mowers, etc.) is to keep the starter switch mashed until you hear fire. NO NO, just hold it for a moment, and when you let go 'varoom,' the XJ fires out of nowhere!....<--if v in spec, and c's are CLEAN, and gas is good.
    Second clue is 'jetted correctly.' This is a bold statement which most NASA engineers would be lying to claim it on their XJ. When it is running, is there any smoke flowing out the exhaust? What color? Running both PODS and open pipes makes it VERY hard to tune properly. The good news is this happened after your tear down, that means it's reversible and can be fixed. I suspect something in your carbs is just wrong. I'd go back into your carbs and make SURE they are first clean, assembled correctly, and then carefully bench synched. See where that gets you.
  5. j12racer
    j12racer Member
    fort worth, texas
    thank you everybody for the quick replies.
    gonna check all the easy checks first (what i should have done before i posted)
    Orignially the bike had pods and custom open exhaust. The guy i bought it from is a guy that knows carbs really well that being said "jetted correctly" is a bold statement. Also before i let it sit it ran well . I need to go over the basis really . I guess i just needed to see it all in posts from you guys.
    a couple more things im curious about. The emulsion tubes: i know they should move and slam down with ease. But should they do this while assmebled and carbs on the bike? I try to move them but they wont budge while the carbs are on the bike and fully assembled.
    I just pulled the plugs and all plugs are black and sooty. they may have been wet but dried by the time i pulled them (severeal hours after starting the bike)
  6. j12racer
    j12racer Member
    fort worth, texas
    Okay just to be clear im not sure if its called the emulsion tube but im talked about the brass cylinder that slides up and down vertically where air comes into the carb.
  7. mlew
    We call those the carb slides, and YES they should move easily. They will have slight spring pressure holding them down but should easily lift with one finger. If they don't then problem found. The emulsion tube is the tube the carb slide needle goes into, it helps the fuel atomize as it enters the air stream.
    Looks like you will need to pull the carbs and give them a through cleaning and inspection.
  8. j12racer
    j12racer Member
    fort worth, texas
    Yes sir. Carb # 3 and 4 Carb slide is stiff and wont go up and down. Sorry abuot the confusion with the name of the part. Im used to carbs that have the needle and slide connected lol. I appreciate your help and another thorough carb cleaning is in order. Hopefully this will fix the problem. Originally when it would start it sounded to me like it was starving for air, maybe this is why i thought that. Thanks again
  9. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    Good to know that you may have found the problem. It is taking me two rounds to learn what the true concept of "clean" means for this carbs. There are so many little parts, springs and passages that must be cleared, it is really easy to over see them.
    After that the next task is to wet-set the floats and bench sync them before going back on the bike for the final tuning.
  10. bigfitz52
    You asked about valve adjustment. Having your valve clearances in spec is critical enough with a stock bike; if yours aren't in spec then trying to tune the carbs on a modified bike will just be that much more impossible.
    If you haven't checked your valve clearances yet, do so. And get them in spec before proceeding.
    You'll have much better luck with a modified bike if everything that's NOT modified is 100% before you try to compensate for the mods.
  11. j12racer
    j12racer Member
    fort worth, texas
    No i have not checked the valve clearances thats next on the list. About 6 months ago the previous owner had bigger cams put in it . Hot cams i think. Im not sure on the size or the clearances or anything. I dont have the paperwork around here somewheres with receipt and possibly specs on it . Im not sure if the "stock" clearance is the same if its aftermarket cams. that would be my question for when i check the valve clearance.
  12. j12racer
    j12racer Member
    fort worth, texas
    o jeeze. At first i just thought maybe the oxidization stuck them but the other day when i had the bike running i didn't notice the slides moving while on the throttle. would this be dut to a vacuum leak or something? I should add that previous owner put a harley petcock on it. which flows well, I just didnt know if it needed to be a vacuum operated petcock
  13. bigfitz52
    A vacuum operated petcock isn't a requirement, just a convenience.
    Valve clearance specs will be the same regardless of the different cams.
    Valve clearance how-to: http://xjbikes.com/Forums/viewtopic/t=14827.html
    Part Deux: http://xjbikes.com/Forums/viewtopic/t=29209.html
    Wet-setting floats: http://www.xj4ever.com/setting%20fuel%20levels.pdf
    Your carburetors are vacuum-operated. When you twist the throttle, you open the butterflies. The carbs then respond to the difference in manifold vacuum in relation to atmospheric pressure and the slides are lifted via the rubber diaphragms due to the vacuum produced "above" them. They were designed to live in a controlled-air volume environment; putting pod filters on them upsets this and makes it that much more necessary that everything else be 110% right if you want to have any hope of them working.
    If your carbs aren't truly, religiously clean and the slides free to move, the diaphragms intact, float levels properly set, etc., they won't work right. Read this: http://xjbikes.com/Forums/viewtopic/t=14692.html and this: http://xjbikes.com/Forums/viewtopic/t=2908.html and have at it.
    Valve clearances greatly affect manifold vacuum hence the need for those to be correct before any serious carb tuning can commence.
    You have a highly-modified bike. If you hope to have ANY chance of getting it running anywhere near close to right, you need to get serious about this and do it thoroughly, correctly and in order. Halfway measures or quick fixes are not going to work. Stop trying to ride the bike and FIX IT.
    If you want to make some actual progress here, then get a manual, get serious and do it right. Otherwise you'll be at this for a while.
  14. BruceB
    BruceB Active Member
    Isle of 8 Flags, Florida
    What Fitz said is right. Found out when I worked on my bike. It is sorta like building a building in a way. If you skip getting the foundation set square and correct, nothing else will come out right. It is a step by step process with these bikes. They like to be romanced just in a certain way and order...:)
  15. RickCoMatic
    Pods ... --> ALONE <-- across the 4-Pack upset the delicate balance needed to have the Diaphragm Pistons RISE as needed.
    The 1/4 -- 2/3 Firing Order causes a rapidly alternating infusion of the Intake Airflow.
    TURBULENCE ... where Turbulence is NOT intended to be present.
    The Intake Air is GULPED into the Air Horn ... when it should be SHAPED and ACCELERATED.
    The SHAPED and ACCELERATED Intake Air passes over the Top of the Main Nozzle ... causing Decreased Pressure within the Tube thereby SIPHONING Main Jet Supplied Fuel up into the Air Stream.
    The Turbulent, non-shaped, poorly accelerated Intake Flow fails to Decrease the Pressure above the Nozzle ... initiating a LEAN Condition.
    Additionally, the Turbulent, un-shaped, non-accelerated Intake Air Flow is GULPED below the Diaphragm Piston ... is of insufficient Shape and Speed to adequately Decrease Pressure below the Orifice at the Piston's Bottom ... resulting in a Less Efficient Pressure Reduction at that Orifice leading to the Piston(s) prolonged Rise ... the Needle(s) are extracted slower further contributing to the Lean Condition.
    Velocity Stacks help SHAPE and ACCELERATE the Flow.
    Some measure to reduce the Turbulence between the 1/2 & 3/4 Carbs might prove helpful.
    Covering the Inboard sides of the 1/4 Pod and the Outboard sided of the 2/3 Pod would --> "likely" <-- reduce the Turbulence which intensifies as Rpm's increase.
    ::: You might experiment by fabricating a set of Shields fashioned by cutting two Clear Plastic Cup lengthwise to be affixed to the appropriate Inboard/Outboard of the Pods to see is a reduction in the Turbulence between Carbs results, :::
  16. j12racer
    j12racer Member
    fort worth, texas
    Thanks everybody. im not trying to ride the bike and fix it. I do have a manual. i refer to it many times a day and study it when im not working on the bike. . Im not trying to fix bare the bare minimum and get away with it. The cams were replaced about 6 months ago. i was under them impression that they would not just go out of spec that quick if they were done correctly when the cams were changed. Since that is not the case i will start from the top. Thanks everybody for your help i appreciate the help and feedback. Now i gotta go get to work
  17. j12racer
    j12racer Member
    fort worth, texas
    Okay gentlemen, once again thanks to everybody who has been helping me out.
    I got a little ahead of myself the other day. i finally got a break from work at 2am so i wanted to work on the bike. I wanted to check the valve clearances first but i did not have feeler gauges, and all the stores are closed being 2am.Planning on going to harbor freight when they open becuase reguardless i need to check the valve clearances. So went ahead and broke that carb rack down and cleaned the carbs, wet set the floats, and changed the oil. I was gonna give the bike the chance just to see if there was any improvemant... It ran great for about 10 minutes then went back to bogging down if i hit the throttle. So as i read in a few other threads that once warm the valves tighten up. so needless to say as planned i went and got a set of feeler guages as soon as the store opened. gonna check the valves tonight, and find some to shims to buy. That being said heres a pic of my plugs. they were brand new now here they are after 10-15 minutes of idle/soft riding.. ok they pics are too big to upload. but anyway CYL1-white CYL2-brown paper bag CYL3-white CYL4-brown paper. bag
    not black and sooty now so im thinking valves in clearance then a bench sync will make a good runner. What say you
  18. Andyam5
    Andyam5 Member
    Luton, UK
    I like the logic of the shield idea, might give it a try
  19. j12racer
    j12racer Member
    fort worth, texas
    Yeah I've edited this same post about 13 times lol. So i guess i was just a little nervous because i know i need to get this exactly right. The hardest thing was trying to determine what "clearance" is as far as pushing the gauge between the cam and shim. But i read a post (sorry i forgot who wrote it ) that said its feels like shaving with a safety razor. That helped me out alot. enough of the blah blah. here's the specs.
    Cyl 1- I .06mm, E .10mm
    Cyl 2- I .10mm, E .20mm
    Cyl 3- I .08mm, E .15mm
    Cyl 4- I .08mm, E .14mm
    so correct me if im wrong please, all are out of spec with the exception of Cyl 2 E (.20mm) should i go ahead and replace that since its so close to out of spec?
    Last question would everybody agree that since most of these are out of spec that this would be my problem with bogging down with throttle after it warms up?thanks to everybody for your help. tomorrow I will be removing each shim to see what shims I need to order.
  20. bigfitz52
    In spec is in spec. Leave #2 exhaust alone, clearances tighten with mileage.
    Those are all tight (except exhaust 2) and yes the motor will run like crap (and you won't get a decent vacuum sync.)
    The rest all need one size smaller shim except exhaust #1, that one will need to come down 2 sizes to get in spec.
  21. bigfitz52
    Also, a bench sync is just to get the bike running so you can do a vacuum sync. Be sure the float levels are accurately wet-set as well.
  22. j12racer
    j12racer Member
    fort worth, texas
    10-4 thanks fitz
    I wet set the floats the other day. so those should be good. moving on to bench syn then vac sync. obviously Im gonna use the search to try and tackle these tasks, but any helpful advice is appreciated.
  23. RickCoMatic
    Do some YICS Tuning.
    Grab a pair of athletic socks.
    2 Cans of Card Cleaner.
    4-Feet of Winter Driveway marker.
    Remove both YICS Gallery Plugs. ( L/R )
    Soak 1" ~ 2" *Patches* of sock with Cleaner. Shove patch(s) through the YICS Passage.
    Repeat until a fresh patch comes falling-out from the open-end as clean as the patch started-out when it was loaded.
    You might have a One Sock job.
    Quite often the Bore is wicked-bad as an overflowing Huggie with a 2/3rds to 3/4ths of whole North American White Striped Skunk.
    (White Striped so as to positively identify what you ran-over as-if the stench didn't leave a doubt. Also to show the Mustang fly-boy's they were not Nazi's.)
    There are deals for Complete Carb Assy Fasteners made of Stainless Steel Allen-type.
    Lube and Exercise New Stainless Allen Sync-screws before Tuning commences.
    Having an Extra-long Ball-headed Allen T-Handle speeds-up the show.
    Remove Idle Adjustment Rod and Spring
    Add-on a Stainless Flat, first.
    Thinnest Nylon.
    Lube the Idle Rod and those New Washers with 3 and 1 Oil using the Precision Applicator and Preset just-about touching the porch at the Linkage.
  24. bigfitz52
  25. j12racer
    j12racer Member
    fort worth, texas
    Im confused lol
  26. j12racer
    j12racer Member
    fort worth, texas
    well ive checked two shims so far . and one was a 275 and another was half readable. I think it says 280A but i measure it and micrometer says 309. ... how much would you rely on the ink stamped number?
  27. j12racer
    j12racer Member
    fort worth, texas
    so my micrometer is not in calibration , but i figured it out. this is what i came up with
    clearances:
    Current shims:
    Cyl1- I 2.95, E 2.75
    Cyl2- I 2.95, E 2.80
    Cyl3- I 2.95, E 2.75
    Cyl4- I 2.95, E 2.85
    these are the shims i need to get according to the chart on fitz's walkthrough.(I think)
    Cyl1- I 290, E 265
    Cyl2- I 290, E in spec
    Cyl3- I 290, E 270
    Cyl4- I 290, E 285
    Please correct me if i'm wrong. today i will be trying to find somewhere local with them or will probably have to order them.
  28. bigfitz52
    OK, you missed one. Exhaust 4 needs a 280...
    I already did your calculations for you...
    Leave exhaust #2 alone;
    Exhaust #1 will need to come down two sizes, from a 275 to a 265;
    and the rest all get one-size smaller shim than what's in there now.
    Once you're done, turn the motor over by hand a few revolutions and re-check.
    Then I'd recommend you do a compression test.
    A good Yamaha shop should have the shims but they may be expensive. Member HogFiddles runs a shim pool, or you can get them from XJ4Ever for about half of what Yamaha gets for them.
  29. j12racer
    j12racer Member
    fort worth, texas
    Yes sir you did. I just wanted to check and make sure I understood correctly. thank you fitz. I was hoping to buy locally , but if yamaha doesnt have what i need i will check out xj4ever. Nothing against shim pools, I would just rather buy new ones and have these old ones as testers and such.. Compression check. will do sir. Thank you
  30. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    E4 should be a 280, you already have a 285 in there.
  31. j12racer
    j12racer Member
    fort worth, texas
    got the valve shims done and checked and rechecked. runs like crap if it even starts.frustrated
  32. bigfitz52
    Good start. That wasn't "the fix" it's a PRE-REQUISITE to being able to properly adjust your freshly serviced carburetors.
    Where are you with those?
  33. j12racer
    j12racer Member
    fort worth, texas
    okay i hope so. Carbs are not synced or anything with new valve shims. Im worried i screwed up some wiring or something. It used to start and idle great. but when on the throttle bog down close to dying. now wont even start 95 percent of the time even with starter fluid. I just wanted to hear it sing one time before a carb sync. I feel like something is wrong with the coils sor something IDK. They are aftermarket coils and the wiring under the tank is a mess.
  34. j12racer
    j12racer Member
    fort worth, texas
    Charged battery. Runs great from until warm. Man when it runs its running good! awesome throttle response feels great but when it got warm it jsut bogged with idle and died
  35. bigfitz52
    Maybe the battery ran flat.
    Below 2500 rpm or so, the bike is running on ONLY the battery; that is normal. The charging system starts to "come online" about 2200 rpm and should be at full output by 2500.
    If you're running it at idle, it can and will run a "marginal" battery stone dead.
    Now back to the carbs. I wasn't talking about sync yet; have you thoroughly cleaned them, replaced pilot screw o-rings, accurately wet-set the float levels and bench sync'ed them? Where are your pilot screws set?
    If not, the carbs need to be fully serviced; then they can be adjusted. Getting the valves in spec is a prerequisite for that.
    This isn't a magical process whereby you touch one thing, and everything suddenly starts working. ALL OF THE ABOVE FACTORS are critical in getting the bike running properly. Any one of them can lead to a lack of success. It all has to be done, carefully and correctly, if you hope to succeed.
    Until you have done ALL OF THE ABOVE don't expect it to run correctly. (It won't.)
    It sounds to me like you have wonky float levels and one or more cylinders are running way rich as a result. Once it warms up, it's acting as though the choke is on when it's not. Float levels or an enrichment plunger/seal issue.
  36. j12racer
    j12racer Member
    fort worth, texas
    Ok Fitz ill go through the carbs again, i already wet set the floats a few days ago, but i will redo them just in case. this may take me a few days lol
    I should mention that the choke cable has be removed becuase the cable cover was breaking. so I was planning just hitting the choke lever on the carbs. Is this a problem?
    Thanks!
  37. j12racer
    j12racer Member
    fort worth, texas
    Thanks!
  38. bigfitz52
    The choke lever at the carbs is "spring loaded" the cable lever is what holds the plungers open when you use the "choke." (Remember that it's not a real choke, it's an enrichening circuit but that won't fit on the label.)
    By all means double-check the floats, wet. If they're fine and in spec, then all you need do is check; easy.
    You didn't answer in regard to the pilot mixture screws and their tiny o-rings.
    Reading back through the whole thread, you said the carbs are clean. How clean? Did you remove the emulsion tubes, and clean them both inside and out? All jets removed and their passages flushed? Float valve seat seals replaced?
    And more importantly: Have you re-jetted at all to compensate for the intake and exhaust mods yet?
    If you're going to tune for extreme intake and exhaust mods, everything else has to be 100%.
  39. j12racer
    j12racer Member
    fort worth, texas
    still havent went to sleep lol. I took the carbs apart. Cleaned the emulsion tubes some things( that aren't rubber) are soaking in carb cleaner. Ive cleaned the enrichment circuit. and everything else i can see find and read about. Please tell me where the pilot mixture screws are. are they the ones on the top of the carb body by the choke? . I obviously can search with the right words or something. Carbs were jetted when i bought the bike. I kind of know the guy. he is supposedly good with carbs. he said he jetted them for pods and stage 2 cam. But when i wet set the floats were upside down lol.
  40. bigfitz52
    The pilot mixture screws are indeed the ones in the top of the carbs next to the choke plungers.
    They need to come out, the passages flushed, and if their tiny o-rings are mashed flat and baked hard they will need to be replaced.
  41. j12racer
    j12racer Member
    fort worth, texas
    yes sir will do . I missed those!!
  42. bigfitz52
    So SLOW DOWN already. What else did you miss?
    You're well on your way to joining the "I've cleaned my carbs 5 times" club, (of which I am not a member.)
    Become a "carburetor dentist."
  43. j12racer
    j12racer Member
    fort worth, texas
    okay so got the pilot mixture screws and everything else done that i could find. the o rings were good not squishy but not hard. felt like a rubber o ring to me. Wet set the floats again. one was a hair off. bench synced. the butterflies were completely shut. I synced them then adjusted the idle screw to where a sliver of light was showing through just like the forum said. I don't know if i jumped the gun but i started her up after all that and it ran super great. but apparently i did jump the gun.
    before all this the bike was bogging down with throttle and then eventually dying. Now its not bogging or dying its more like a studder. Twist the throttle a little and it studders for a second and then it takes off like a rocket. My thought was fuel mixture or something, because its like it would eventually clear out and rev up. Pulled the plugs all 4 are black as can be and sooty. also at start up it didn't just kick over and boom start up. it would fire for a second or two then start up. (the start up issue might be a low voltage from battery issue?? ill check the battery tomorrow ) Also getting a compression gauge tomorrow. what about the studder and black plugs?
  44. j12racer
    j12racer Member
    fort worth, texas
    Just now saw this post. Yes your right i need to slow down. This is the second time ive cleaned the carbs. and if i have to take em off to clean them again then.... 3rd times a charm lol. I already know im gonna have to break em down again from my previous post. Unless you say im at that easy adjustment stage (doubtful). I already went and bought more carb cleaner though.
  45. j12racer
    j12racer Member
    fort worth, texas
    will vacuum sync fixed the studder throttle/4 pitch black sooty plugs problem? i dont know where to go from here
  46. sektorgaz
    sektorgaz Member
    Western MA, United States
    You need to stop skipping the recommended steps, do everything in order like suggested: valves, double-triple checks the carbs, ensure absolutely no vacuum leaks, then you can vacuum sync and color tune to get rid the rich condition (black plugs).
    Just take it one step at the time and be 100% that it is up to spec, or you will end up repeating a lot of the work.
  47. j12racer
    j12racer Member
    fort worth, texas
    thanks sektorgaz for the reply, I have done all of the recommended steps. valves,carbs triple checked/cleaned, carbs, bench synced, wet set floats. (if im missing something please tell me ) I'm not trying to skip steps, I'm only asking what the next step is.
  48. sektorgaz
    sektorgaz Member
    Verify that you don't have any slight vacuum leaks: take an unlit propane torch and spray near the rubber carb boots and throttle shaft seals. If the engine rpm goes up you found the problem. You'll need to fix it before syncing as tuning will be difficult and inaccurate.
    If all is well, proceed to sync and tweak the pilot mixtures (colortune). This should take care of the off-idle stumble.
    PS: Like someone else mentioned, you have a modified bike. There's no cookie-cutter recipe when it comes to those. Here's a thread with some more pointers: http://www.xjbikes.com/Forums/viewtopic ... ories.html
  49. j12racer
    j12racer Member
    fort worth, texas
    thanks again sektorgaz,
    I will check for vac leaks in the morning.and maybe proceed to vac sync and colortune.
    Also i should mention last start up i noticed the diaphram slide acts crazy when throttled. Its not smooth and just goes up and down with little "jump" . i just watched a video of the carb slides on a xj1100 on the church of clean thread and the carb slides go up and down with throttle fairly smoothly. all four of mine aggressivley "jump" while going up and down with throttle. (maybe a vac leak?) if cleaned the carb slide and the diaphram's boots seal nicley in the carb hat. maybe this is normal or a sympton of a vac leak?
  50. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    your diaphragms may not have stayed seated.... you should be able to push them up, and they come down slowly
