HELP, 82 XJ750 MAXIM Fork Seal Replacement
Discussion in 'XJ Technical Chat' started by 82NewToMe, Aug 24, 2013.
  1. 82NewToMe
    82NewToMe Member
    Harrisonburg, VA USA
    2 Photos attached. One shows the stage ofdisassembly I am currently at, the other shows the bolt I cannot "rattle" out. Advice needed. I am replacing the fork seals and am stuck at this point.
  2. 82NewToMe
    82NewToMe Member
    Also, if anyone would like a photo of any internal piece, speak up.
  3. 82NewToMe
    82NewToMe Member
    Used the socket trick, photo offer still applies if anyone needs anything.
  4. 82NewToMe
    82NewToMe Member
  5. 82NewToMe
    82NewToMe Member
    Now I'm struggling with getting the oil seals out. I'm letting them rest up right now for the next round of pulling and prying...
  6. 82NewToMe
    82NewToMe Member
  7. k-moe
    Did you remove the circlip that holds the seals in? After they are removed you can pull on the upper fork legs (the same way that you would use a slide hammer) to remove the seals.
  8. 82NewToMe
    82NewToMe Member
    The circlip is out, but these forks don't have the bushings that can "slide hammer", once you remove the damper bolt the inner leg slides right out past the seal.
  9. 82NewToMe
    82NewToMe Member
    After a bit of pulling and prying, got them out and reassembly was a snap, nice new seals...
  10. k-moe
  11. 82NewToMe
    82NewToMe Member
    Damper removal tool :)
