XJ650 Maxim cafe cbr RR front end
Discussion in 'XJ Modifications' started by dondjbmini, Sep 22, 2013.
  1. dondjbmini
    dondjbmini New Member
    NC
    Hi all i have been lurking in the background sucking up all the knowledge here
    so now its time to share what i have been working on a budget cafe style bike
    started life as an 82 650 Maxim picked it up for $300 only 12000 miles but not running for three years sat under a tarp in a garden. 6 months later i have almost finished total cost $850 front end is from a 2004 CBR 600 RR
    so here it is hope you like it
  2. Ninety5PoloZ
    Ninety5PoloZ New Member
    Wisconsin
    Looks good, what had to be done to make the front end fit?
  3. Ninety5PoloZ
    Wisconsin
  4. dondjbmini
    NC
    Front end conversion was quite simple used the xj bearings lower is a straight swap top had the inner opened up 1mm and had to trim 4 mm of the bottom of the head. There are not enough threads for the locking collar so I drilled the collar and used an Allen screw to lock it
