RobbieRobot Cafe Racer Project in pictures
Discussion in 'XJ Modifications' started by RobbieRobot, Jul 16, 2013.
  1. RobbieRobot
    RobbieRobot Member
    North Yorkshire, England
    Seat painted and lacquered.
  2. RobbieRobot
    RobbieRobot Member
    Cardboard template for forming the dash warning light bracket.
  3. RobbieRobot
    RobbieRobot Member
    Preparing to cut out the aluminium sheet using the template to mark it out.
  4. RobbieRobot
    RobbieRobot Member
    Cutting out the instrument warning light bracket.
  5. RobbieRobot
    RobbieRobot Member
    Roughed out instrument warning light bracket.
  6. RobbieRobot
    RobbieRobot Member
    Instrument warning light bracket drilled and polished.
  7. RobbieRobot
    RobbieRobot Member
    LED warning lights being fitted and wiring soldered to terminals.
  8. RobbieRobot
    RobbieRobot Member
    Heat shrink tubing covering the soldered wires.
  9. RobbieRobot
    RobbieRobot Member
    Connecting up the wiring inside the head light. Notice the new bar-end mirrors.
  10. RobbieRobot
    RobbieRobot Member
    Instrument warning light bracket fitted and working.
  11. BaldWonder
    BaldWonder Innocent Bystander
    Oberlin, OH
    This is really making me want to redo my brakelight bracket. I used steel, not the much-lighter aluminum you are.
  12. RobbieRobot
    RobbieRobot Member
    Tank sprayed and finished with several coats of lacquer giving it a deep lustre.
  13. RobbieRobot
    RobbieRobot Member
    Still looking good though.
  14. BaldWonder
    Oberlin, OH
    That says a lot, coming from you. Your work is impeccable.
  15. kinen1
    kinen1 Member
    Perth, Western Australia
    Robbie,
    that is a beautiful warning lights bracket mate!
    kinen1
  16. BikePike
    BikePike New Member
    Wales, UK
    Wow, Loving your project! I hope to make my own brackets from Aluminium.
  17. Corrupt_Reverend
    Corrupt_Reverend Member
    Central California
    Very beautiful build sir. One question:
    It looks as though you mounted the SS mudguards using aluminium brackets. If this is the case, are you worried at all about galvanic corrosion occurring?
    In my trade, we often use non-conductive spacers/sleeves/washers when this may cause issue so I'm always a bit paranoid about it.
    ~Rev.
  18. Andyam6
    Andyam6 Member
    UK, Beds
    The paint's looking bootiful
  19. colehole
    colehole Member
    Panama City, FL
    Love that aluminum panel for the dash lights! Also what bike did your master cylinder and clutch perch come off of?
  20. RobbieRobot
    RobbieRobot Member
    Thanks Kinen 1. How are things progressing at your end?
  21. RobbieRobot
    RobbieRobot Member
    Thanks BikePike.
  22. RobbieRobot
    RobbieRobot Member
    Thanks for the complimentary feedback and thanks for alerting me to the possible problems with galvanic corrosion between the dissimilar metals. As I understand it, stainless fasteners in aluminium don't pose too much of a risk, however I will now revisit the assembly method and fit non-conductive washers where possible. I believe things are less likely to corrode when kept dry. Do you know how quickly the corrosive effect will take place if left unchecked?
  23. RobbieRobot
    RobbieRobot Member
    Thanks Andyam6, I am pleased how it's turned out especially as I've only used rattle cans. I actually got the tank on and connected up yesterday and had a few test runs up and down my street. So far so good.
  24. RobbieRobot
    RobbieRobot Member
    Thanks colehole. The master cylinder and front brake assembly with adjustable lever came off a FireBlade. I had a bit of amazing good luck when I bought the master cylinder. I bought it off eBay from the photo but it didn't say which bike it was from. It came without a lever and to my amazement a spare lever that I happened to have from my previously owned beloved FireBlade fitted perfectly. The clutch lever assembly which is also adjustable, is from a Kawasaki ZX7R if memory serves. Almost all of the stuff I've fitted was obtained through eBay.
  25. Corrupt_Reverend
    Central California
    I'm not really an expert on the subject but I'd imagine in a salt-free environment, it would be quite a slow process. If your area uses salt on roads or you live near the sea, I'd be a bit more concerned.
    If it's not a giant hassle to install some insulating spacers, it certainly won't hurt. If not, just keep and eye out for white corrosion in the aluminium bits.
  26. BaldWonder
    Oberlin, OH
    And a little anti-seize compound. It helps it insulate the metals from having direct contact as well, and it makes taking it back off in 20 years a lot easier. As my father-in-law likes to say: its not for you, its for the next sonuvabitch who has to take it off.
  27. Corrupt_Reverend
    Central California
    Yes, very good addendum! In a pinch, even just a little grease on the threads will go a long way.
  28. RobbieRobot
    RobbieRobot Member
    Most of the aluminium brackets that I've made are only semi-polished with the intention of going back to do a more thorough job once she's all together in an initial assembled form. You can spend too long on the detail and take forever to get nowhere if you are too fussy. Once I'm happy with the overall configuration I will return to the detail and improve it. That's when I can address the issue of galvanic corrosion. I live about six miles from the coast but the roads where I live are salted from around November through to March, however I won't be using the bike on a day to day basis. Fortunately I can pick and choose when I ride her. Great feedback though thanks guys.
  29. FtUp
    FtUp Well-Known Member
    pacific northwest
    I like your father in law, he is definitely a forward thinker.
    CN
  30. RobbieRobot
    RobbieRobot Member
    Test Ride
  31. lhicks
    lhicks New Member
    Nova Scotia
    I love your work and I love the warning light set up. I was thinking of doing something similar. Where did you get those lights?
  32. RobbieRobot
    RobbieRobot Member
    Hi lhicks. The lights can be found here http://www.ebay.co.uk/itm/261021225148? ... 1439.l2649
    Thanks for your kind words. Keep us posted with your progress.
  33. RobbieRobot
    RobbieRobot Member
  34. RobbieRobot
    RobbieRobot Member
    Starting to look like a Cafe Racer
  35. RobbieRobot
    RobbieRobot Member
    Brand new Motad 4 into 1 (Below) replaces old one (Above)
  36. BaldWonder
    Oberlin, OH
    Ha, now that's f'in sweet.
  37. RobbieRobot
    RobbieRobot Member
    New exhaust now fitted
  38. RobbieRobot
    RobbieRobot Member
    New Motad 4 into 1 from rear
  39. RobbieRobot
    RobbieRobot Member
    More pics of the new exhaust
  40. RobbieRobot
    RobbieRobot Member
    Shiny Silencer
  41. RobbieRobot
    RobbieRobot Member
    Closer shot of collector box
  42. RobbieRobot
    RobbieRobot Member
    Just needs new handlebar grips to finish off this bit.
  43. RobbieRobot
    RobbieRobot Member
    Right handlebar
  44. RobbieRobot
    RobbieRobot Member
    Left handlebar
  45. RobbieRobot
    RobbieRobot Member
    Front view
  46. RobbieRobot
    RobbieRobot Member
    Still needs seat pad
  47. RobbieRobot
    RobbieRobot Member
    Rider's eye view
  48. Groundhangers
    Groundhangers Member
    Sydney, Australia
    Thats one very sharp setup. Be proud.
  49. xHondaHack
    Orange CT
    I'm very impressed with the detail you are putting into your build. It looks awesome!
    Where did you source the control switches? I need to get ones like you used so I can get more tank clearance at full lock with my bars.
    Tony
  50. RobbieRobot
    RobbieRobot Member
    Thanks Groundhangers, that's very kind of you.
