Recently Aquired an XJ900F
Discussion in 'XJ Technical Chat' started by Rain_Man, Dec 8, 2013.
  1. Rain_Man
    Rain_Man New Member
    Ashford, Kent, England, UK
    Hiya,
    I have Recently Aquired an XJ900F :)
    Do all the 900's have a vibration felt through the seat between 4 & 5 thousand RPM ? or is there something up with mine, she runs brilliantly, but im just curious to find out if this is normal :)
    Cheers,
    Rain Man
  2. SimonRef
    SimonRef Member
    Hull East Yorkshire UK
    Hi,yes My XJ900 does this, it equates to about 60 mph in fifth gear,it disappears as you speed up or slow down.Balancing carbs might help alleviate it to less noticeable levels.Welcome to the wonderful world of XJ's, a much maligned and underrated Bike. :wink:
  3. Rain_Man
    Rain_Man New Member
    Ok, thank you & yes, from 60 mph through to 75 mph (4 - 5 thousand RPM on my bike) it vibrates, but above & below this, she is silky smooth, if im in this zone & decelerate or accelerate she still vibes until she is out of this zone.
    Its gonna take some getting used to this lol
    Other than the vibes, she is a Great bike, just gotta put some new Fork Springs in as the Originals have compressed over the years, so im bottoming out alot at the moment :/
    Rain Man
  4. murray
    murray Member
    Sydney Australia
    As well as new progressive fork springs , one grade heavier fork oil makes a big difference, cheers , Murray
  5. Rain_Man
    Rain_Man New Member
    Cheers murray, i will bear that in mind when i change them :D
    With Hagon progressive springs, do i need to make spacers for them or are they already the same length as the original springs would have been when new ?
    Getting back to the vibes, will i hurt the engine if i ride in the vibe zone alot, cos, to be honest, i usually ride between 65 & 70 mph anyways, i just wanna be sure im not gonna hurt the engine ?
    Cheers,
    Rain Man
  6. SimonRef
    SimonRef Member
    No need to worry about Engines their Bulletproof.Asl long as you change Oil and filters regularly youre good to go.If the Cam chain is in Adjustment all is good.The Primary chain can go thats an engine Tear down.If the Engine sounds like a Bag of Spanners when cold its a good indication of a Duff primary Chain.
  7. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    Is it just like a slight buzz or like full on bar jiggle? Normally in that range our bikes tend to "hum" and that wont cause an issue. But i normally just ride faster. ;)
  8. Rain_Man
    Rain_Man New Member
    Thanks SimonRef, my bike has only done 22464 miles since new, whats the average mileage when the Cam & Primary chains need replacing ?
    My engine does sound a bit dodgy when starting up after its been left a week & the temp outside is below 8 degrees Celsius, but when warmed up, she sounds fine, i really don't wanna have to get it stripped down so soon :(
    What tell tale signs should i look out for with the Cam & Primary chain wear ?
    Yes, sometimes i can be quite paranoid, more so when i have not had the bike long :roll:
    The buzz is only through the seat, my bars don't vibrate at all & yes when i take it past that rpm range, i find im at 90+ mph & i dont wanna lose my licence lol
    Cheers,
    Rain Man
  9. SimonRef
    SimonRef Member
    At 22000 your Engines is hardly Run In :D .These engines are good for 150,000 miles if looked after.If you like giving it the Beans, change your oil more frequently maybe Twice a season.A loose Cam chain really shakes the Bike through.Transmission snatch is a good indicator of a primary chain on its way out,again on Tickover you can hear it thrashing away.Like I said at 22,000 miles youre in an Enviable position ,no need to worry just Enjoy your Bike.
  10. Rain_Man
    Rain_Man New Member
    I do have transmission snatch when riding, yet, when i put the bike on its center stand & try to feel it by moving the rear wheel forwards & backwards, i cant feel any snatch, i also dont hear any thrashing at tickover, even if i rev it a bit, man im really paranoid now :?
    Cheers,
    Rain Man
  11. SimonRef
    SimonRef Member
    I really dont think you've got anything to worry about your Low mileage Engine indicates this.Vibration and transmission snatch could be indicators of carbs in need of balancing,if you are not happy with your engine try that you will get smooth pickup good tickover and hang on tight acceleration.
  12. Rain_Man
    Rain_Man New Member
    Cheers SimonRef, i have no idea if the carbs are balanced or not, the engine pulls like a train & feels very responsive, tho i have not tried a fast WOT, so i assume they must be balanced up quite well :)
    Cheers,
    Rain Man
  13. sektorgaz
    sektorgaz Member
    Western MA, United States
    Pics or it didn't happen :lol:
  14. Rain_Man
    Rain_Man New Member
    Here are 2 pics of my 1988 XJ900F on the day i rode her home :)
    Cheers,
    Rain Man
    Franz likes this.
  15. adrian1
    adrian1 Active Member
    Nice tidy example! Check for rust at lowest point at rear of tank though....
  16. Rain_Man
    Rain_Man New Member
    I removed the tank & had a look at the rear bottom part of tank & there are no signs of rust that i can see, the paint finish is all smooth with no bubbling, so guess im ok :D
    Cheers,
    Rain Man
  17. mtnbikecrazy55
    nice bike!
    brakes ought to be looked over though, old lines, old pads, and check the date of the tires, anything over 5 yrs toss
    Welcome RM!
  18. Rain_Man
    Rain_Man New Member
    Thank you, the brakes are fine, brake lines seem ok, no bulging, so i think im ok on that & i also put new tyres on her a few days ago, new brake pads will have to wait til the new year tho :)
    Cheers,
    Rain Man
  19. adrian1
  20. Rain_Man
    Rain_Man New Member
  21. SimonRef
    SimonRef Member
    Heres Mine
  22. Rain_Man
    Rain_Man New Member
    Wow, i wish mine was as clean as yours, your cases are perfect :)
    Cheers,
    Rain Man
  23. gunnabuild1
    gunnabuild1 Member
    2 very tidy 900's gentlemen.I like the blue on blue/white colour scheme.
  24. SimonRef
    SimonRef Member
    Thank You Sir.
  25. 750E-II_29Rbloke
    South Cheshire, UK
    Nice to see the big guys coming out to play :) I have to say, the 31A/58L/4BB1 chassis is the best handling & sweetest ride of the whole XJ series... even if the 750 motor is the best engine lol 8)
    Just my biased opinion kicking in there (I have to believe I have the best of both worlds or I'd not be able to love her as much :lol: )
    Nice looking bikes the both of them though on a rare serious note ;) and good advice on the aged brake hoses. Even if they're not old & internally crumbling the difference braided hoses make is like night & day and you'll kick yourself for not upgrading sooner when you feel how positive the lever is.
  26. Rain_Man
    Rain_Man New Member
    Thank you, i am enjoying my 900 a lot, its actually nice to ride a quiet bike for a change, my main ride is a 1999 Kawasaki Vulcan 1500 with loud pipes lol
    Cheers,
    Rain Man
  27. SimonRef
    SimonRef Member
