Rotary tool suggestions?
Discussion in 'Hangout Lounge' started by Newb21, Jan 24, 2014.
  1. Newb21
    Newb21 Member
    Cardiff, South Wales
    Hi guys I'm at the point in my build now that the engine needs to be cleaned and polished. I'm thinking that a cordless Dremel type tool is needed because the shed the engine is in has no electric supply to it. Looking for value for money but it still needs to be pretty robust. Can you guess make some suggestions please?
  2. wizard
    Take the lump & get it soda blasted.
  3. Newb21
    Newb21 Member
    As much as I'd love to, not really an option, no way to transport it.
  4. paul.hardy
    paul.hardy Member
    Tasmaina - Australia
    It would fit in the boot of a TAXI cab
  5. bigfitz52
    You'd be amazed at how well you can clean up one of these motors with nothing more than the correct cleaners and techniques and a lot of elbow grease rather than resorting to soda blasting or a rotary tool.
    Pick up a can or two of citrus based foaming engine cleaner at the auto parts store, be sure it specifies for use on cold engines. You'll also need a jug of mineral spirits (usually sold as "paint thinner" here in the States) and a couple of nice, stiff nylon parts-cleaning brushes. Plus an assortment of old toothbrushes and Scotchbrite pads.
    You're also going to need a product sold here as Aircraft Paint remover, again from the auto parts; this is for stripping the old clearcoat before polishing.
    It doesn't take anything fancy to turn this:
    Into this:
    Here's the "how-to" http://xjbikes.com/Forums/viewtopic/t=22125.html
  6. Newb21
    Newb21 Member
    Once again Fitz comes to my aid, thanks alot buddy :)
  7. wizard
    How long have you got, Newb ?
  8. Newb21
    Newb21 Member
    I want to get the engine prepped and ready as quickly as possible without cutting corners. The frame will be going off to the powder coaters in the next week or so. So I want to get the valve clearences and paint job done while it's away, so a few weeks I guess.
  9. Hotcakesman
    Hotcakesman Active Member
    South Dakota
    I was told Carb Cleaner works great
    my motor is nasty
    but not my concern
    safety is my concern now
  10. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    i bought one of these a few weeks ago from a local supermarket, it was only £15, a household steam cleaner
    first aply paint stripper,
    then steam clean, whilst wire brushing
    be sure to leave a door open though
  11. Newb21
    Newb21 Member
    That looks like it's doing a great job, can you put up some of the completed pics please? minus the steam lol
  12. bensalf
    yorkshire ,england
    yes i'll post some more pics when i get further on , i only started this today.
    i will have to reaply the paint stripper, as it is only a cheap mild one that i already had .it was'nt very efective on the stuborn crankcases.
    will see if a second coat melts it.
    stu
  13. bigfitz52
    I'd be concerned about the paint stripper attacking the valve cover gasket, the head gasket and the base gasket. Or any other gasket you hadn't planned to renew.
    You also want to be careful not to force moisture IN through seals that weren't designed to keep things out, as they face the other way, to keep oil in the motor and transmission.
