virago jumped timing?
Discussion in 'Other Motorcycles' started by joshs700n, Oct 1, 2013.
  1. joshs700n
    joshs700n Member
    mass
    i was riding my xv1000 virago pretty hard it wouldnt acellerate anymore now when you rev the engine the timing chain rattles runs slow and doggy now but it still idles good and both cylinders still run evenly. hello everyone
  2. mlew
    I really doubt it jumped time. Ihave seen guite a few Viragos with broken rocker arms. Seems that they are prone to failure but easily replaced. Remove the valve adjustment covers and have a look.
  3. joshs700n
    joshs700n Member
    mass
    i did remove them and even ran the engine with it off my didnt see anything wrong just hear a rattling noise that gets bigger as you rev the engine like the one of the cam chains is really loose but you think that would cause it and the loss of power? thank you for your help
  4. joshs700n
    joshs700n Member
    mass
    i think i just removed the front valve adjustment covers
  5. mlew
    Check both of them, the intake valve cover is a pain to get to. It is possble for the cam chain tensioner to loosen up or even break a chain guide. You will have to remove the engine side covers to see them.
  6. joshs700n
    joshs700n Member
    mass
    i have removed the round gold engine side covers and both chains feel pretty tight
  7. bigfitz52
    Then check your valve clearances and do a compression test. Make sure you don't have a hole in a piston.
  8. joshs700n
    joshs700n Member
    mass
    i did a compression test on the virago 1000 150 in both cylinders
  9. mlew
    !50 is good, I would look into the timing chain guides to see if one has broken. You can do a quick by removing the upper cam chain cover on the head and see if the chain is loose.
  10. joshs700n
    joshs700n Member
    mass
    i have done that and the both chains feel very tight
  11. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    Might pull the Left side cover for the noise.
    I've seen where the starter had been replaced without taking the side cover off which sometimes leaves the tension clip laying inside the Left cover bouncing around the starter idler,clutch & flywheel gears.
    On the XV700 I had, the Ignition module was the problem for loss of power. Had it repaired, no more problem.
    With the side covers off you can then check your timing.
  12. MiCarl
    I had a 1000 or 1100 with a problem like that. Timing wasn't advancing on one cylinder, so lots of intake noise but no power.
  13. joshs700n
    joshs700n Member
    mass
    i noticed the intake vavle clearence on the rear cylinder is dead tight
  14. joshs700n
    joshs700n Member
    mass
    ok Im pretty sure I figured the problem now.. I put the rear cylinder on top dead center pulled the cam chain tensioner and it wouldn't push in like it was jammed and when I tried winding it up it wouldn't do anything and it is jammed and will not push in at all
  15. joshs700n
    joshs700n Member
    mass
    well I broke a chain guide in the rear cylinder..
  16. Chris E
    Chris E New Member
    Wichita Falls, Tx
    I'm having the same problem with my 85 xv1000 but I have 90 PSI in the second cylinder 120 PSI in the first cylinder and the timing marks are way off this is my first bike with the v-stroke style engine so it's kind of new to me but to my understanding from what can be seen in the two photos that I uploaded timing marks are way off could this be due to a broken cam chain tensioner or something somebody help
